Author Topic: How to: Fit 12v socket in boot  (Read 22972 times)
Offline Golf_GT_TDI
  • 2015 (65) Golf GTD, 2016 (66) Golf GTI
« on: 14 May 2012, 22:10 »
12v socket for boot, cheap and easy upgrade, fits right hand side of boot
Time to fit: 10 mins
Tools required: Hole saw
Wiring required: None, wiring is present on all Golf's
Parts required:
7L6919341F - Housing - £6.33 + VAT
1J0867218 - Reinforcement plate - £0.26 + VAT
1J0919309 - Socket - £5.02 + VAT
1] Remove carpet trim panel from right hand light cluster area
2] Pop out boot light and disconnect wiring
3] Locate the 12v socket's wiring (2wires with a 3pin plug) its just taped to light cluster wiring
4] Decide on position you'd like the socket to be in
5] Use hole saw to drill hole through the trim panel
6] Test fit the 12v socket's plastic housing
7] Here is how the complete assembly fits together
8] Next its just a case here of holding reinforcement plate on inside of the trim panel while pushing the 12v socket assembely through, then fit the plastic nut and secure hand tight.
9] Connect wiring to 12v socket, find a 12v device anything from a pump to phone charger to test it, it should work right away.
10] Reconnect wiring to boot light, re-fit the small carpet trim panel and admire your work...
Job done, hope this guide was useful, any questions please ask.
« Last Edit: 14 May 2012, 22:13 by Golf_GT_TDI »
Offline richw911
Re: How to: Fit 12v socket in boot
« Reply #1 on: 14 May 2012, 22:14 »
Nice guide  :cool:
Offline dasan
« Reply #2 on: 17 May 2012, 16:15 »
Nice guide - something to do this weekend :) will be useful if I need to use the 12v air compressor.
VW Golf GTI - 1.8T 2003 - Reflex Silver
Offline m4rt1ngti
« Reply #3 on: 05 June 2012, 20:12 »
Is this the right one? as it has a 3 pin terminal and in your pics it only has 2 wires going into it?
http://www.ebay.co.uk/itm/360223697320?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_2993wt_942
Offline Golf_GT_TDI
« Reply #4 on: 05 June 2012, 20:16 »
Yes thats the same part, I confirm the wiring in boot has 3 pin socket with only 2 wires, thats how its meant to be  :wink:
Offline m4rt1ngti
« Reply #5 on: 05 June 2012, 20:24 »
Sweet just thought id check :laugh:
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #6 on: 05 June 2012, 20:32 »
Sweet, I'm gonna whack one of these in my mk3 boot. Handy for when pumping the mountain bike tyres up.
Offline m4rt1ngti
« Reply #7 on: 08 June 2012, 19:04 »
dun :laugh:
