Author Topic: smoking on idle when hot ??  (Read 8205 times)
Offline bobbieboy69er
  • MK4 1.8T AUM
Re: smoking on idle when hot ??
« Reply #10 on: 15 May 2012, 16:29 »
Hi sorry it's took a while to get bk to your comments it's seems to b more white than blue and it goes when driving car has done 112k services upto date , think I've done the catch can right I followed a guide on here I believe , the smoke itself comes from the back when it does smoke a blip of the throttle a bit more comes out then it clears hope this helps
I did check ye turbo for cracks and etc when I rebuilt it violent level not dropping neither oil level ???
Are you sure theres actually something wrong, my car smokes when cold.... mainly becuase its cold, also condensation has a part to play and your engines on the choke.....
MK4 1.8T AUM|30mm Eibach Springs|Milltek cat back|4mo rear valance|pipercross filter|R-tech Stage 1 Remap|Baileys DV|Powerflex Front and Rear Bushes|312mm Front Brakes|Creation Motorsport TIP and hoses|17" TT Ronals|  220BHP
Offline rockmonkey69
« Reply #11 on: 15 May 2012, 16:54 »
As above, it could be nothing, are you losing coolant?
Offline madhead1987
« Reply #12 on: 15 May 2012, 17:56 »
dont seam to be loosing anything its confusing f**k out of me ive checked all the pipes are on right could it be the hockey puck not working forgot what they called ?
« Reply #13 on: 15 May 2012, 19:06 »
It may well be that you have a blocked breather hose, if your not losing any fluids it's pretty unlikely you have a major problem. Go through your breather hoses leading to and from your catch tank as well as any standard pcv hosing just to make sure it's not clogged.
Offline madhead1987
« Reply #14 on: 15 May 2012, 19:12 »
will do ill report back 2 moz cheers
  • MK4 1.8T AUM
« Reply #15 on: 15 May 2012, 19:16 »
Sorry, why did i think the subject was smoking when cold!? :laugh: :laugh:  Ignor me!! :rolleyes:
Offline madhead1987
« Reply #16 on: 15 May 2012, 19:44 »
lol i do it all the time
Offline Scott D
« Reply #17 on: 16 May 2012, 02:16 »
If you've done the catch can check the breather hose which goes into the engine make sure its connected tight and sealed - might even be worth renewing that pipe and clip if not already done so.
I had a similar problem using the original hose as the outer plastic had perished making it a struggle to fit correctly.
Caused white smoke after revving while idle as seen here - http://www.youtube.com/watch?v=Nq1t_LRvXqQ
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline madhead1987
« Reply #18 on: 16 May 2012, 07:10 »
I've just checked the hoses before I go work there all tight and secure still confusing as hell I'm gna wip the plugs out see what they look like :-/
