Author Topic: Rear sub axel Refurb & clean up or replace?  (Read 2770 times)
Offline clipperjay
« on: 07 May 2012, 20:22 »
Sorting my rear sub axel and not sure think the metal is quite solid, but not sure to replace as they arent cheap!  :undecided:
Offline Mr Blue
Re: Rear sub axel Refurb & clean up or replace?
« Reply #1 on: 07 May 2012, 20:42 »
looks 'ok' but see a big big flaking off? If so replace!
VW only stock the correct bolts for these. Aftermarket ones dont work when tightening (bolt heads to big)
Offline clipperjay
« Reply #2 on: 07 May 2012, 21:02 »
I've still got the original bolts they came off easy so not rounded or damaged threads!
There seems to be about 1mm of flaking, but no where near the bolt holes just the space where the brake shield had rotted against it. I think its okay just need to clean it up.
The metal where the bolt holes are are still new?
Unless there is a balance thing issues with a few grams of metal flakes?
Under neath is fine.
Offline DOA
« Reply #3 on: 07 May 2012, 21:46 »
The big flake on the flat isnt an issue (certainly wont cause any imbalance, it doesnt rotate and neither does the shaft lol), the issue is at the root of the shaft where the rot has got to it. Saying that, there is more than enough shaft material to keep you safe and I doubt many other golf stub axles of the same age knocking around on the road are in much better shape. If you were ultra paranoid you could get the root of the shaft turned back to good metal and crack tested but its a bit OTT......
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #4 on: 08 May 2012, 00:02 »
You've had 20 years out of it.... Replace it (whilst you can) - then you know it's good for another 20.....  :laugh: :laugh: :laugh: :laugh:
For More Info Click To See;
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #5 on: 08 May 2012, 02:02 »
Have em shot blasted Jay, they'll come up like new, then i'd be tempted to get them powder coated :cool:
Thom
Offline Mr Blue
« Reply #6 on: 08 May 2012, 11:34 »
ahh looked like a huge chunk flaking off in the first pic. Look fine but remember to order those bolts from vw
Offline Seanl
« Reply #7 on: 08 May 2012, 14:51 »
Looks like a proper crack to me.  :shocked:
I replaced mine when I did the bearing up too tight, and scored the shaft.  :rolleyes:
I just replaced the bearing at first, but after a couple of days I had to change it, as I kept hearing what was just road noise, but in my mind it was the bearing grinding on the stub axle!
Just get it changed for peace of mind, cos you will be constantly worried otherwise!  :wink:
Offline clipperjay
« Reply #8 on: 08 May 2012, 15:10 »
TBH there is no cracks and that surface rust will be cleaned up!
I've ordered new bearings kit which have dust caps oil seals.
The disks are on order and pads aswell.
The caliper union bolt is finished rounded that right away.
Two new splash covers aswell!
Its costing me over £100 per side just to make it go through the MOT properly!
I'll have to cut back the copper brake pipe and re flare it onto a new union nut, but its been a right B*tch to sort it out!  :sad:
