Author Topic: THS Pancake and Turborevs SMIC  (Read 3994 times)
Offline Cummins20vT
Re: THS Pancake and Turborevs SMIC
« Reply #10 on: 09 May 2012, 18:16 »
i thought it would be obvious that a FMIC would be better at cooling than a SMIC.
Offline lukeyyyyyyy21
« Reply #11 on: 09 May 2012, 18:19 »
no matter how good the flow rates are...infact i would have thought that those SMIC which are like cubes would create more lag due to being deep. think of it like running a hose. That's why the TT twin side mounts with a cross pipe work well as standard and efficient for the levels as they gradually cool the air from to the other not all in one go in a deep cube shaped intercooler.
anyway FMIC has a long contact area against cold wind, a SMIC has a very small contact area... Therefore what Nick's found on the thousands of cars hes tuned seems right.
« Last Edit: 09 May 2012, 18:21 by lukeyyyyyyy21 »
Offline cullygti
« Reply #12 on: 09 May 2012, 18:24 »
think it also depends on the fmic setup the cheap ebay kits can cause a lot of heat soak due to the pipe set up which then causes turbo lag which then makes your car down on power etc
« Reply #13 on: 09 May 2012, 18:46 »
tobys car had an ebay intercooler and made 304, from what's been said the flow rates in them are fine.
Offline Toby
  • Car - less
« Reply #14 on: 09 May 2012, 18:51 »
eBay cheapy ftw  :cool:
Currently down under
Offline cullygti
« Reply #15 on: 09 May 2012, 19:08 »
yes but he had a load of other mods to back it up not just a stage one on a k03 and the cooler was 3 times the size of the tiny ones on ebay  :grin:
Offline Cummins20vT
« Reply #16 on: 09 May 2012, 19:15 »
just think if he ran a forge fmic it could be more?? :shocked:
« Reply #17 on: 09 May 2012, 19:21 »
From what I heard the flow rates were fine?
Offline cullygti
« Reply #18 on: 09 May 2012, 19:22 »
on whos tobys or the ones with the mile long pipe work
« Reply #19 on: 09 May 2012, 19:23 »
tobys, but obviously toby and nick can answer it better, hear it from the horses mouth :D
