Author Topic: How much does an R32 swap in a mk3 cost????  (Read 3553 times)
Offline gti gaz
Re: How much does an R32 swap in a mk3 cost????
« Reply #10 on: 05 May 2012, 22:16 »
never seen a mk 3 r 32 with 4 wheel drive all the ones i have s  :grin:een have been 2 wheels down to the cost its crazy
 Any one in cornwall lets sort more meets!!!!
« Reply #11 on: 05 May 2012, 22:27 »
I would imagine it would be cheaper to get a mk3 synchro imported and then drop a 32lump into that. That how I would do it if a customer wanted it doin.
This would be the only way, to start cutting floorpans = ballache with the dvla.
Offline Leon27
« Reply #12 on: 06 May 2012, 11:49 »
Very good idea
Or if you're good with a hacksaw you can try this... Know its a Mk1 but principle will be similar...
http://www.stanceworks.com/forums/showthread.php?t=11983
Gavv8
« Reply #13 on: 06 May 2012, 14:12 »
I suppose anything can be done given enough time/money/expertise, would be an awesome project if you could get it off the ground.
Offline boneybradley
  • Back in a Mk3...
« Reply #14 on: 06 May 2012, 14:51 »
as said earlier.......dvla are funny about changing the cars structure, so a 4wd conversion would be a no-no!.
you would need to start with a syncro and add the engine onto that (several people have done a rhd conversion onto a vr6 syncro)
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #15 on: 07 May 2012, 22:55 »
rhd conversion onto a vr6 syncro is definitely the best way to go about this then start thinking about whats under the bonnet.
