Author Topic: Air filters  (Read 1767 times)
Offline Steve_PD
Re: Air filters
« Reply #10 on: 28 April 2012, 17:58 »
Offline Tazzy
Re: Air filters
« Reply #11 on: 28 April 2012, 18:07 »
pipercross here as well, better than k&n imo, although ill be changing to a bmc cda soon
If It Comes Off, Modify It!
Offline stfc_gti
Re: Air filters
« Reply #12 on: 28 April 2012, 18:07 »
ive seen that thread, thanks but if i was to go for a cone filter will everything i need come in the box or will i need to buy anything separate?
2002 1.8T GTI AUM, Standard (not for much longer)
Offline Scott D
Re: Air filters
« Reply #13 on: 28 April 2012, 19:12 »
If its designed for your model then should come with all parts required to fit.
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Re: Air filters
« Reply #14 on: 29 April 2012, 00:18 »
You will need a breather filter for the SAI pipe
Offline shaft69
Re: Air filters
« Reply #15 on: 29 April 2012, 12:12 »
I was woundering what is the best air filter for my annoversary, standard box with pannel filter or cone induction kit? Thanks in advance :)
hahahaha Annoversary!!! Anniversary.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline lukeyyyyyyy21
Re: Air filters
« Reply #16 on: 29 April 2012, 12:17 »
don't get a bmc. r-tech said that they actually lose you hp.
