Author Topic: crankshaft pulley  (Read 1982 times)
Offline biddy
crankshaft pulley
« on: 24 April 2012, 18:45 »
hi all what is easiest way to get pulley off need to do a cambelt change got a golf gti 8v
Offline madmanmart
Re: crankshaft pulley
« Reply #1 on: 24 April 2012, 18:47 »
Impact gun and suitable 6mm allen bit.
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline harlemex
« Reply #2 on: 24 April 2012, 18:50 »
secure the pulley somehow. (oil filter strap or thin rope wrapped around pulley) undo the the allen bolts and you are done.
Offline biddy
« Reply #3 on: 24 April 2012, 19:32 »
thanks for replys so just remove them and pulleys come off and then i can remove cambelt cover correct
Offline madmanmart
« Reply #4 on: 24 April 2012, 20:35 »
Correct
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #5 on: 24 April 2012, 22:20 »
I find if i tap in an allen bit then give it a hefty crack with a hammer, it will come out quite easily.  Impact gun is always the way to go though.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline gti gaz
« Reply #6 on: 24 April 2012, 22:22 »
impact gun all the way mine was a right pig but impact gun made light work of it
 Any one in cornwall lets sort more meets!!!!
