Author Topic: WINDOW TINTING QUESTION  (Read 4362 times)
Offline ryanbrook
Re: WINDOW TINTING QUESTION
« Reply #10 on: 23 April 2012, 21:58 »
Cheers for the reply's :) I do like the look better on a 3 door mind, but hopefully will get away with doing the rear and rear sides :)
Thanks again.
Offline ryanbrook
« Reply #11 on: 23 April 2012, 21:59 »
I have done tinting before, was OK tbh. Will give it a go
Offline Sprakie2008
« Reply #12 on: 23 April 2012, 22:03 »
I think you need to do the rear window in 2 or 3 horizontal sections and hide the joins along the demisting element lines this will help against creases in the corners .
this just makes me want to bang my head every time i hear it  :cry:
no need to chop it mate! i do this several times a week and never once in my life have i had to chop it into sections! :)
Mk3 Mad!
Offline Screech16v
  • MK3 20vt AGU
« Reply #13 on: 23 April 2012, 22:09 »
How do you get it done in one with no creases,do you heat it or something
Offline ryanbrook
« Reply #14 on: 23 April 2012, 22:17 »
what percentage do you's go for? I was gunna go 20%, seems about right.
Offline Sprakie2008
« Reply #15 on: 23 April 2012, 22:19 »
on a mk3 golf GTI (with the spoiler ofc) i would spray a light mist of water on the OUTSIDE of the window.. then stick the tin to the outside of the window and trim the bottom edge, using the glass in the window as a guide to run your knife round, must be an incredible sharp knife or else it may crease the tint..., then clean the inside of the window, with meths if available to get rid of all dust and static, then spray the window with water and a tiny drop of washing up liquid (not hand soap or any kind of skin cleaning products as it leaves a residue behind, hense why some people get ripples in their tint!)
then peel the backing paper off (if you struggle use 2 pieces of tape to grip each side while you peel them apart), then scrap it from the bottom upwards.. once you start to get to the top curve of the window then put a slight slit in the top corner, but leaving about 15mm away from the glass, then slowly scrape the tint at 450 to the rest of the window, if you see a crease forming follow the last procedure with the slit, if you leave the 15mm you will find that it should tear itsealf into place until it touches the window..
then leave it on the car for ATLEAST 1 hour on a warm day, or 2 hours on a cold one... then trim where required..
i will have to do a tutorial for the forum one day if enough people are interested?
some people find it easier doing it otherways, this i find the easiest method how ever...
Mk3 Mad!
Offline Screech16v
  • MK3 20vt AGU
« Reply #16 on: 23 April 2012, 22:48 »
Well im allways up for learning different/easier methods ,so yeah a tut would be  :cool:
Offline stainesy
« Reply #17 on: 24 April 2012, 10:00 »
in my younger days when i like tinted windows i used to only tint the rear side windows as if you have dark interior it makes the rear one look tinted anyway as the car goes dark inside. although that was very dark tint i used back then.
Offline search
« Reply #18 on: 24 April 2012, 14:26 »
youtube is your best friend on this
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline off_the_cuff
« Reply #19 on: 24 April 2012, 16:17 »
i've not tried it yet but apparently you lay the tint on the outside of the back window (wet)
and use a heat gun to shrink the fil to the curve of the window then transfer it to the inside. something like that lol
