Author Topic: Removing door seals  (Read 3678 times)
Offline Jimble
Removing door seals
« on: 23 April 2012, 10:29 »
Right then, i've been having major issues with creaking doors, i thought i'd sorted it at one point by claying and sealing the apateur (sp) but as it turns out it was only a temporary fix :angry: So the car went in on saturday for Service, cruise fitting, door seals and the damn clunk coming from the off side rear qtr! They've told me it needs booking in for a whole day to have ALL the door seals replaced! :shocked: internal and external, now in on one hand i'm pleased that even though the car is 2 years old they are still willing to do this, on the other hand i'm a bit nervous as to what is required for this?
It's being done regardless because the creaks are unbearable to me, my wife and 90% of other people that get in the car but can someone tell me whats involved to replace these seals? Particularly the external ones.
Cheers chaps.
James
Offline R32UK
Re: Removing door seals
« Reply #1 on: 23 April 2012, 11:25 »
i used to have this when reversing up an uneven drive. it is down the flex in the chassis and the door seals rubbing against each other.
this used to be a huge problem with eos's so VW actually have a bottle of something (lube type stuff) that they apply to the seals..... it cured mine  :smiley:
hth
Offline JoeGTI
« Reply #2 on: 23 April 2012, 11:41 »
Cheers chaps.
James
I've had creaks and groans from the door seals in every car I've had in the last few years (though my current car seems ok!), and the only thing that sorted it for me was "Gummi pfledge". A quick application of this stuff every few months and no more creaks.
Available on ebay for a few quid.
It's the felt-like material on the top of the door frame rubbing against the metal of the door opening that causes it.
Offline dubber36
« Reply #3 on: 23 April 2012, 13:30 »
I wonder how long it will be before the tight, creaky seals, start wearing the thinly applied paint away.
Offline Edi35
« Reply #4 on: 23 April 2012, 17:06 »
hth
My wife used to have an Eos and I used the water sealant (lube) to keep it water tight and this also made a huge difference to the squeaking made by the rubbers when they dried out. Used it once every six months, worth a try.
Current: GTI Edition 35 Candy White 5dr DSG 19" Glendale, RCD510+DAB, Dynaudio, Storage Pack, Parking Sensors
Gone: Edition 35, GTI Mk6, Edition 30, GTI Mk4, GTI Mk3, GTI Mk2 and my favourite the UR quattro
For those that dont know DSG is an electronically controlled dual-clutch multiple-shaft manual gearbox
Offline Jimble
« Reply #5 on: 23 April 2012, 17:09 »
Cheers chaps.
James
I actually bought some of that and made absolutley no difference, infact probably made it worse tbh. :undecided:
@Gilly, it's called Krytox, they put some on on saturday to see if it helps till they replace the seals.......
It didn't :angry: my drivers door hinge had also become loose but they've tightened that up so it's not a problem.
Good news is cruise control is cool, bad news is it's about 4-5 mpg worse with it on. :huh:
Offline dubber36
« Reply #6 on: 23 April 2012, 17:34 »
That's because it can't antisipate hills, either to "roll" down, or gain a bit of momentum under light load in order to pull up the other side. It will only save you fuel by keeping your speed down on an empty motorway, where it may otherwise creep up.
Offline JoeGTI
« Reply #7 on: 23 April 2012, 17:44 »
Really? I find that the car always maintains speed whether its going uphill or downhill. If I'm on on upward incline, I can feel the car giving it more throttle, so as to maintain speed on the hill. Likewise, I can feel the throttle pulling back when going downhill.
Maybe you would anticipate these things quicker yourself though, or maybe would be less inclined to keep the speed up when going uphill.
Offline dubber36
« Reply #8 on: 23 April 2012, 18:17 »
Exactly my point. When driving ecconomically you would roll down hill on a very light throttle, where cruise control would be holding you back. Towards the bottom of the hill, you would build up a bit of speed to carry you up the other side, whereas cruise would not know you were about to climb until it started doing it. Ecconomy driving is all about antisipation and conservation of momentum (think of riding a bike). Cruise control can never compute that.
Offline Awry
« Reply #9 on: 23 April 2012, 18:48 »
I had creaking doors and found out it wasn't the door seals but the locking mechanism. Spraying some silicon works. So does polishing the metal door hook. On my car the metal door hook was creaking against the plastic on the locking mechanism. I still do use gummi pflege to keep the rubber from drying out.
Reflex Silver MK6 GTI 3-door DSG, DCC, Sunroof, 18" Detroit, Xenons, LED tail lights, RCD 510, Dynaudio, Media-in, Bluetooth, Cruise Control, Winter Pack.
Added Milltek 3" Race exhaust and H&R suspension.
