Author Topic: Getting most out of ko3s!!!  (Read 6523 times)
Offline Chris.
Re: Getting most out of ko3s!!!
« Reply #20 on: 29 April 2012, 19:17 »
Just get it fitted!
Click For Build Thread
Offline Dave_IOW
« Reply #21 on: 29 April 2012, 19:27 »
Superb mate  :wink:
Will be fitting my WMI kit as soon as the weather picks up, then give R-Tech a bell :smiley:
Get your missus on umbrella duties!
:grin:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #22 on: 29 April 2012, 21:38 »
Superb mate  :wink:
:grin:
Yep I can see that happening :grin:
Will enquire at work about getting some more pipe tomorrow (might even strike lucky and find some kicking about in the loft  :wink:) then start looking for pump/tank locations :cool:
Also I found a place in the UK that will do a level sensor for £25 + delivery :smiley:
Offline Dave_IOW
« Reply #23 on: 29 April 2012, 21:49 »
Offline Chris#101
« Reply #24 on: 29 April 2012, 22:55 »
yeah it was me.
248bhp and 300lbft lbft potential torque (ran 297lbft once on R-tech dyno)
Water meth and vernier pulley with a set of forged rods  and ported OEM exh. manifold will be added when rebuild.
Engine still runs spot on ;)
How did you make so much power from a ko3s? :lipsrsealed:
 what was your spec list?
« Last Edit: 29 April 2012, 22:57 by Chris#101 »
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline Chris.
« Reply #25 on: 29 April 2012, 22:58 »
k03s
forge actuator with yellow spring
007p yellow
forge TIP
3" MAF with new sensor
pipercross panel filter smoothed airbox with 3" cold air feed
New N75 C
THS Intercooler
calibra turbo 315cc injectors
Modded throttle body
NGK R plugs
new OEM coil packs
3" decat downpipe into straight through 2.5" exhaust into remus backbox
lots of custom mapping
tesco 99 fuel.
PCV delete
Charcoal canister delete
R-tech uprated fuel pump
New fuel filter
« Last Edit: 29 April 2012, 22:59 by Chris. »
Offline Chris.
« Reply #26 on: 29 April 2012, 23:01 »
Offline cullygti
« Reply #27 on: 29 April 2012, 23:21 »
ah there you are aint seen you on here for a while hows things dude you all fixed now  :smiley:
Offline Chris.
« Reply #28 on: 29 April 2012, 23:53 »
:). Near enough all fixed now.  Just the part where bones get back to full strength over a year
Offline cullygti
« Reply #29 on: 29 April 2012, 23:59 »
 :cool: main thing is your getting back there
