Author Topic: Wheels spacers/lowering advise  (Read 3554 times)
Offline daz veedub
  • Operation 1.8t bolf
Re: Wheels spacers/lowering advise
« Reply #10 on: 22 April 2012, 20:33 »
es but you was running a fat 9j wheel daz  :grin: he as only got 7.5j et35
no mate when i had 20mm on the rears i had these on
Offline cullygti
« Reply #11 on: 22 April 2012, 20:34 »
ah back in the day  :grin: i remember now mate  :embarassed:  :grin:
Offline Steve_PD
« Reply #12 on: 22 April 2012, 21:02 »
Buy wheels which fit out the box :cool:
ET30 9J
Offline Chris#101
« Reply #13 on: 22 April 2012, 21:41 »
Steve those are 'gaaaaawjuss  :tongue: and I bet the price tag was too  :grin:
Thanks for the input so far people  :nerd:
Next question is, what length wheel bolts do I need to buy ???
thanks
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline dom
  • Back in a Mk4
« Reply #14 on: 22 April 2012, 21:43 »
Standard bolts are M14x1.5 with 27mm thread (I think). If your running after market wheels then you'll need a tapered seat, but if your running OEM wheels then you'll need a radius seat.
Offline Chris#101
« Reply #15 on: 22 April 2012, 21:53 »
So am I right in thinking il need 27mm+ 15mm(for spacer)= 42mm long bolts?
then same for the front?
I believe ive got oem wheel but il double check!!
How much was your car lowered in your pictures? bud
 :smiley:
Offline dom
  • Back in a Mk4
« Reply #16 on: 22 April 2012, 21:56 »
The rears are down as low as they'll go with the adjusters still in, not sure about the front. Somewhere around 50mm at a guess :wink:
