Author Topic: Fuel Pressure Regulator for VW Golf Audi 1.8T Turbo Gti  (Read 6467 times)
Offline golf-sib
  • Турботазик
Re: Fuel Pressure Regulator for VW Golf Audi 1.8T Turbo Gti
« Reply #10 on: 22 April 2012, 15:56 »
4bar vs 3bar means you get 33% more fuel, if its a custom map then they will account the current 4bar reg that you fit on and adjust the injectors accordingly in the map.
However if its just a generic map it may have been written for 3bar in mind, this means the additional fuel will benifit in some parts of the map but reduce performance in other parts of the map.
Also what engine is it, I know the AGU stock injectors max out at around 235bhp @ 3bar, and the AUM injectors go further @ 3bar, all depends on what power your after?
Also keep in mind just upping the FBR isn't a means of increasing performance as maps are written lean and rich at various parts as these factors have an effect on max bhp, max torque and how the turbo spools/boosts. Plus its usually better to change injectors to a higher cc than just upping the FBR reg as the injectors won't love you for running them at max duty!
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline Toby
  • Car - less
« Reply #11 on: 22 April 2012, 16:13 »
mines mapped on 3 bar.
300bhp saab red's - r tech custom map  :cool:
Currently down under
Offline pickles
  • Next!!!
« Reply #12 on: 22 April 2012, 16:46 »
gr8 info thanks, so all in all it isnt really needed unless your going for big power, its an AGU, lookin to get a k03s possibly k04 but theres loads of sh!t i wana do first, really wana just map it with the k03s and mods for now am i right in sayin could see around 200 + bhp on a stage 2 map with the reccomended mods
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline shaft69
« Reply #13 on: 22 April 2012, 17:08 »
Think it depends on your map tell the truth revo say fit 4bar fpr with stage 2 map with ko3/s remap. Sure APR do too I've got one but will fit when fitting,255 fuel pump, Saab yellow and 3" maf for remap.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
