Author Topic: engine dies under load mk3 gti 8v  (Read 2192 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: engine dies under load mk3 gti 8v
« Reply #10 on: 20 April 2012, 11:16 »
Coil pack causes more of a misfire effect,  crank position creates more of a "cut out" effect, even though it comes back to life off load.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline bobbin1982
« Reply #11 on: 20 April 2012, 12:25 »
luckily i bought a CPS..
I just put the new dizzy and rotor on and she seems to rev more freely but i still have the cutting out effect so its time to put the cps on :(
Do i really need to take the oil filter off and the mount off to do this? that will mean a new filter and replacing the oil.. seems a little too much to replace a sensor as they are normally easily servicable items
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #12 on: 20 April 2012, 13:16 »
Oil filter doesn't need to come off although it will give you more room. You will need to remove the front engine mount though to gain access to the single bolt holding it in.
Offline javalin
« Reply #13 on: 20 April 2012, 13:23 »
as above - no need to remove the oil filter. (on the 8v at least)
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline Greengolf
« Reply #14 on: 10 May 2012, 18:57 »
So did you change the CPS? and if so did it fix the issue?
