« Reply #16 on: 19 April 2012, 00:01 »
should be good for 230 with those mods and standard SMIC although as said heatsoak is noticeable when driving hard.
had 233bhp and 240ft/lb with the SMIC, torque increased to a peak of 265ft/lb with the FMIC on the same map.
if you are planning on changing the intercooler then do it before having a remap. I fitted the FMIC after mapping and while there is more torque the extra pipe work has caused lag which I'm positive can be reduced by mapping to suit.
THS/Forge are the best option and aside from trimming the standard bumper are a very good fit
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
