Author Topic: vr6 wont start  (Read 7254 times)
Offline bosco
Re: vr6 wont start
« Reply #10 on: 24 April 2012, 19:07 »
I know someone who had a smiliar problem, was the crank sensor. Have you had it scanned for codes?
Tested the crank sensor with a multimeter and got 571 ohms. Havent scanned it yet will hopefully be able to tomorrow.
1990 mk2 1.6 daily
1990 20v turbo project learning as I go
Offline bosco
Re: vr6 wont start
« Reply #11 on: 24 April 2012, 19:08 »
Are you getting a buzzing noise from your fusebox when cranking over?
No, no noise coming from the fusebox.
Dont think I can hear the fuel pump priming either.
1990 mk2 1.6 daily
Offline javalin
Re: vr6 wont start
« Reply #12 on: 25 April 2012, 12:53 »
if the plugs are black - new plugs might be worth while?
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline VR6_Wherry
Re: vr6 wont start
« Reply #13 on: 25 April 2012, 13:32 »
Fuel pump relay?
Offline AudiA8Quattro
Re: vr6 wont start
« Reply #14 on: 25 April 2012, 14:41 »
I would check the basics first - fuel, compression and ignition.
Although you don't have to check in that order  :laugh:
Offline bosco
Re: vr6 wont start
« Reply #15 on: 25 April 2012, 23:04 »
Hopefully have new plugs some stage tomorrow.
Fuel pump relay can you test it or just replace it?
Have fuel going to the rail anyway cause I disconnected the feed and cranked it and fuel came out. Was quite dark/murky though (been sitting up for a while)
1990 mk2 1.6 daily
Offline javalin
Re: vr6 wont start
« Reply #16 on: 26 April 2012, 08:15 »
apparently fuel goes off - so would drain and replace.
James
Offline bosco
Re: vr6 wont start
« Reply #17 on: 26 April 2012, 22:34 »
Plugged in today and got this from it. All im really concerned about is the immobilizer fault. I cleared the fault and it hasnt come back but the car will still fire and run for a few seconds then cut out. Any ideas or is it off with the ECU and get it defeated?
Thursday,26,April,2012,17:53:26:11321
Chassis Type: 1H - VW Golf/Vento III
Scan: 01 02 03 08 12 15 25 41 56
Address 01: Engine        Labels: 021-906-256.lbl
   Part No: 021 906 256
   Component: MOTRONIC M3.8.1  HS V02
   Coding: 00000
   Shop #: WSC 01269
   VCID: CFA7CB370DC68D1
1 Fault Found:
00668 - Supply Voltage Terminal 30
            07-10 - Signal too Low - Intermittent
Readiness: N/A
Address 03: ABS Brakes        Labels: 3A0-907-379.lbl
   Part No: 3A0 907 379 E
   Component: ABS/EDS ITTAE 20 GI V00
   Coding: 03704
   Shop #: WSC 00000
   VCID: 2C5D3CBBDC10169
1 Fault Found:
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
            35-00 -  -
Address 15: Airbags        Labels: 6N0-909-60x-VW2.lbl
   Part No: 6N0 909 603 E
   Component: AIRBAG VW2          V00
   Coding: 00069
   Shop #: WSC 01269
   VCID: 346D24DB04204E9
No fault code found.
Address 25: Immobilizer        Labels: 1H0-953-257.lbl
   Part No: 1H0 953 257 B
   Component: IMMO VWZ3Z0T3337786 V00
   Coding: 09600
   Shop #: WSC 01332
   VCID: 2A513AA3D6E4089
1 Fault Found:
00546 - Data wiring faulty
            27-00 - Implausible Signal
End   ---------------------------------------------------------------------
Address 01: DTCs cleared
Address 03: DTCs cleared
Address 15: DTCs cleared
Address 25: DTCs cleared
   Coding: 00000
   Shop #: WSC 01269
Readiness: N/A
   Coding: 03704
   Shop #: WSC 00000
1 Fault Found:
            35-00 -  -
   Coding: 00069
   Shop #: WSC 01269
   Coding: 09600
   Shop #: WSC 01332
Mode 01 - PID 01 : Readiness  --  Address 10
Number of DTCs stored: 0  --  MIL Status: MIL ON
Misfire monitoring:  Passed
Fuel System:  Passed
Comprehensive Components:  Passed
Catalyst monitoring:  Failed or Incomplete
Heated catalyst monitoring: Not installed.
Evaporative system monitoring:  Failed or Incomplete
Secondary air system monitoring: Not installed.
A/C system refrigerant monitoring: Not installed.
Oxygen sensor monitoring:  Failed or Incomplete
Oxygen sensor heater monitoring:  Failed or Incomplete
Exhaust Gas Recirculation: Not installed.
Fuel System:  Passed
Fuel System:  Passed
Fuel System:  Passed
OBD DTCs erased
1990 mk2 1.6 daily
Offline bosco
Re: vr6 wont start
« Reply #18 on: 01 May 2012, 14:01 »
Anyone shed any light on the immobiliser fault code?
1990 mk2 1.6 daily
Offline willz94
Re: vr6 wont start
« Reply #19 on: 02 May 2012, 17:06 »
same problem with my vr buddy!
00546 - Data Wiring faulty: Implausible Signal
Possible Symptoms
Engine not starting / immediate Shutdown
Malfunction Indicator Light (MIL) ON
Possible Causes
Wiring and/or Connector(s) from/to Immobilizer Control Module (J362) faulty
No Signal or Implausible Signal on W-Line between Immobilizer Control Module (J362) and Engine Control Unit or Fuel Cut-Off Valve Control Unit
Immobilizer Control Module (J362) incorrectly coded
Possible Solutions
Check Wiring and/or Connector(s) from/to Immobilizer Control Module (J362)
Check Immobilizer Control Module (J362) Coding, Baud Rate Setting
Check/Replace Immobilizer Control Module (J362)
Special Notes
Under certain circumstances this code may be stored after improperly operating the Vehicle/Ignition. For example after the Engine has stopped the Ignition is switched on again immediately (Engine Control Module is still in the Start-Up Phase).
In such a case switch off the Ignition and wait at least 10 seconds before switching it back on. Then check and clear Fault Codes.
as a added problem all my windows decided to go down and refuse to go back up :') good thing i have a garage
