Author Topic: Blue smoke and engine codes  (Read 2088 times)
Offline 1.6mk4GOLF16v
« on: 14 April 2012, 17:22 »
blue smoke when i rev it, smells like theres alot of unburn petrol in it or maybe burning to much petrol, over fuelling perhaps?
codes that came up were:
16804 - catalyst system bank 1, effeciancy below threshold
            P0420 -35-00--
17811 - EGR system, regulation divergence
            P1403-35-10
17566 - Manifold pressure sensor (G71): implausible signal
            P1158-35-10
1.6 16v AZD
RS8s 225/35/19
Full powerflow decat exhaust
Blanked EGR
Pipercross panel filter
watch this space for the rest...
Offline rockmonkey69
Re: Blue smoke and engine codes
« Reply #1 on: 14 April 2012, 18:30 »
Too much fuel otherwise known as running rich gives black smoke not blue, your burning oil too, this might be the reason your catalytic converter is potentially blocked up.
« Reply #2 on: 14 April 2012, 19:08 »
ive decat my exhaust pal, any other ideas?
is there a way to check lamba in bank 1? (manifold)
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
« Reply #3 on: 14 April 2012, 20:58 »
Your 16804 is more than likely the result of having a decat. You can run some logs to check if it's working. Mind I would be more concerned about the blue smoke though.
« Reply #4 on: 14 April 2012, 21:14 »
Blue smoke is oil being burnt so you have problems with valve stem seals or piston rings.
« Reply #5 on: 15 April 2012, 14:02 »
cheers guys will look into it asap
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
