Author Topic: Starting, or not as the case may be  (Read 3271 times)
Offline Sam
  • Sam I am
Re: Starting, or not as the case may be
« Reply #10 on: 13 April 2012, 12:46 »
Dizzy was 180 out, but she still wont start. Here is a video of the plugs in action, I assume they should have a little more 'pazaz'n than this?
Offline SoundillusioN
« Reply #11 on: 13 April 2012, 13:15 »
I don't think the sparks will have much 'pazaz' while earthed like that.
Oh and as far as giving the Metering head a helping hand, you don't need to take it to bits, just move the plate up and down a couple of times and ensure it can move freely.  not that I've ever had to do this.  Despite their antique nature, I have never had an issue with one yet.
« Last Edit: 13 April 2012, 13:17 by SoundillusioN »
Offline Sam
  • Sam I am
« Reply #12 on: 13 April 2012, 13:46 »
So open the air box and fettle the plate a couple of times? Carb cleaner or somthing on it too?
I always test my plugs like this, i used to just rest them on the frame of my mx bike back in the day and it worked so resting them on the engine is the same thing no?
« Reply #13 on: 13 April 2012, 14:54 »
Yeah just lift the Metering head off the airbox and gently push the plate upwards to replicate air flow pushing it up, when you let go it should come back down on it's own.  Check it does this smoothly and rests properly.  Do it a couple of times.
If you really want to go mad on it, you could remove the injectors and test the fuel rates according to plate movements but this requires quite a bit of setup beforehand.
I just don't think resting plugs on anything will give a strong connection compared to pressure or clamping. It works because the power is high but may not give you the same spark you'd expect when fitted.
Offline mk2bal
« Reply #14 on: 13 April 2012, 15:09 »
Surely there's nothing wrong with the equipment, you've just missed something on re-assembly. If everything worked prior to head coming off then the metering head is fine-they don't just stop working for no reason (never seen one failed yet). Check all timing, all wiring, pull the flow off the m/h and check you have fuel, then either pull an injector or remove a plug to confirm fuel getting in. Check things like throttle microswitch for correct function, and all vac hoses, electrical connections etc. I assume your pump primes fine etc on ignition? I've had my kr 9a and abf engines in + out a million times, and its never a hardware issue if you havve starting/running problems, its always been because I've left something off and either forgotten or over looked it.
Offline tomp
« Reply #15 on: 13 April 2012, 16:39 »
Try bypassing your kstar and plug the lead directly into your ignition amplifier, oh and make sure the ECU tray is bolted down properly, a bad earth on this was giving me a poor spark....
Offline danny_p
« Reply #16 on: 14 April 2012, 01:16 »
16v metering heads can fail if you look at them in the wrong way,
if you cam and ignition timeing is good,   take the plugs out burn them clean   they will have got soaked trying to start it with timeing out.   if that dosent get it going i normaly find somethign flamable and spary it at the throttelbody when crancking.   it'll soo let you know i it wants to run
all the VW's have gone bar 1.
