Quote from: just an 8v on 10 April 2012, 13:51Quote from: Dogbot on 10 April 2012, 13:49Quote from: just an 8v on 10 April 2012, 13:47Ohh sounds promising, which wires though do you know the colours? are they the ones directly connected to the head unit.my second post was relating to sheilaghs problem however i will pop out to car in a moment an look for you cant rremember of the top of my headOkay cheers, so far ive swapped the red and yellow around but to no affect, problem persists. If im still doing the right thing ill try to make it permanetly live. Is this easy to do? Sorry Im such a noob at these things.Personally i dont believe making any radio or electrical equipment permanantlyuy live is a good idea, will result in flat battery's
I ran a live straight from the battery, it worked but you had to remember to turn it off! After a couple of months the ingnition switch failed anyway, so i would just replace that, save you in the long run!
@ Just an 8v,change your ignition switch they are £5 and easy to swap out this will fix your issue,no need to bodge the live feed
