Author Topic: cheap clutch  (Read 9125 times)
Offline sprout99
Re: cheap clutch
« Reply #20 on: 19 April 2012, 07:50 »
What power are you running to have to fit a stage 2 clutch?
don't know but std one started slipping after 3000miles
I have since worked out car was overboosting badly - had to get map smoothed out.
« Last Edit: 19 April 2012, 08:51 by sprout99 »
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
Offline Rhyso
Re: cheap clutch
« Reply #21 on: 19 April 2012, 08:52 »
Sounds like it might have been contamination? A new standard clutch even with a remap should not slip  :undecided:
Still, a bargain for someone looking for a new clutch  :smiley:
Offline sprout99
Re: cheap clutch
« Reply #22 on: 19 April 2012, 11:02 »
i thought that when i got box removed but dry as a bone. Replaced it with stronger unit
and sent this one off to sachs for a check - Turned out ok.
The problem was the boosting being too strong. All sorted now. Just have a kit surplus to requirements
Oak green mk2
V50 D5 Sportwagon
