Author Topic: Fitting a KO3s - TIP Hose  (Read 3433 times)
Offline palmtree
Re: Fitting a KO3s - TIP Hose
« Reply #10 on: 03 April 2012, 23:56 »
K03s couple of mm bigger than an K03
That's why you need a silicone tip as it'll easily stretch the extra couple of mm over the inlet where a standard K03 metal tip won't
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #11 on: 04 April 2012, 13:30 »
The turbo end of my TIP is bigger than that anyways lol
Offline rio_gti
« Reply #12 on: 04 April 2012, 13:48 »
if i got the wrong tip on my turbo will i get a leak then? as lately i can here a vaccum cleaner noise like a turbo spool when the turbo kicks in, but you can also hear the spool up aswel  :huh:
Offline palmtree
« Reply #13 on: 04 April 2012, 16:52 »
The only reason to have the TIP for you engine code is so the ports aren't reversed and you don't need to blank one off, makes no difference at the turbo end
Offline AD1.8T
« Reply #14 on: 04 April 2012, 17:37 »
I get this aswell ! And ive just changed all the vac hoses and boost pipes all thats left is the tip
