Author Topic: Fog lights  (Read 1623 times)
Offline gizmomk3
  • on my way
Fog lights
« on: 29 March 2012, 22:11 »
Fitting some fogs to my mk3 I do not have the whirring there so was wondering could I put my own switch in or will thay have to be off the pull switch for the lights??
And if I put them on a switch are thay still classed as fogs???
Re: Fog lights
« Reply #1 on: 29 March 2012, 23:51 »
Use the proper headlamp switch with the double pull postion, keeps it legal etc.
Offline gizmomk3
  • on my way
Re: Fog lights
« Reply #2 on: 29 March 2012, 23:55 »
I can still make my own wiring loom thow???
Can't I??
Re: Fog lights
« Reply #3 on: 30 March 2012, 00:03 »
Can't I??
Well if you really want to however quicker and easier to buy the correct loom, it is plug and play.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Fog lights
« Reply #4 on: 30 March 2012, 06:12 »
I should have a spare loom at some point over the next week or so if you're interested mate?
Re: Fog lights
« Reply #5 on: 30 March 2012, 06:16 »
Ideally you'll need the correct dash mounted switch with a double click out knob and second fog warning illumination BUT you can utilise the standard one by pulling the rear fog light switch half way. Not the best way to go about it though.
Offline gasketface
Re: Fog lights
« Reply #6 on: 30 March 2012, 11:17 »
I do'nt know if this is any help but i unwittingly fitted a gl switch to a gti.The gl one is only one pull out as the car it came off only had rear fogs.However,on a gti a gl switch lights both lots of lights up on just one pull.It was on an R reg if it makes any difference.
Offline vdubnut
Re: Fog lights
« Reply #7 on: 30 March 2012, 18:38 »
changed switch and the loom on my tdi wasnt a bad job at all :)
