Author Topic: Lowering Caps **with pics  (Read 4522 times)
Offline JC
  • Back in the North.
Re: Lowering Caps **with pics
« Reply #10 on: 30 March 2012, 07:33 »
That I am sure will be fine under load.
where theres blame theres a claim  :grin:
Offline gasketface
« Reply #11 on: 30 March 2012, 11:10 »
I used those plates once.When i bought them new i found the centre hole was slightly too small so i took the excess paint off with a dremel.If you have just the plate and the strut with no spring on it that plate should just slide down the shiney shaft of the strut.If it sits on top the hole is too small.The wider part of the shiney shaft which starts just below the thread goes inside the bearing,the cap goes below this.That bearing is not moveable when it's seated correctly.
In your opening post you have 2 pics.The one on the left shows the bearing upside down.
Offline kahunajb
« Reply #12 on: 30 March 2012, 11:41 »
Yeah sorry what I meant was you can unseat the lowering cap from the bearing not unseat the bearing because the hole in the middle of the cap is a wider diameter than the diameter of the shiny shaft  :grin: The bearing doesn't move.
« Last Edit: 30 March 2012, 11:46 by kahunajb »
Mk1 Leon Cupra TDI - Keeping
Mk5 Golf GTI - Revo Stage 1 - FOR SALE £5,250
Mk3 GTI 16v Anniversary - OEM+ - Gone :(
Mk4 GTI 2.0 - Slow - Good Riddance
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #13 on: 30 March 2012, 21:45 »
Likewise, the centre hole on mine were very tight and had to file mine out slightly.
