Author Topic: The "Get Fielder On The Track" Thread  (Read 20983 times)
VeeDubGTI16v
Re: The "Get Fielder On The Track" Thread
« Reply #20 on: 08 June 2005, 10:34 »
how about a bit more camber?
Offline Horney
« Reply #21 on: 08 June 2005, 10:45 »
I'm not sure what happens to the suspension under cornering on the Golf. The mini handles much better better with a 1.5 - 3 deg of negative camber on the front wheels. Effectively giving you maximum tyre to tarmac contact on the outside wheel of a corner and increasing grip. This is great except you loose tyre to tarmac contact on the straights so it's a kind of trade off. Proper racers will alter the camber depending on whether it's a twist circuit or one with lots of straights.
I have tried giving the Golf some negative camber on the front to see if it handles better, but due to not being able to set it up properly I've just worn the insides of my tyres badly. Didn't seem to make a huge amount of difference but I haven't tracked it yet and to be fair the level of grip on a proper circuit is 100 times better than the public roads so I'd never be able to figure out if it is an improvement.
Ooops sorry for the long thread, can you tell I'm bored at work?
Nick
Offline Organisys
  • Old and Slow...
« Reply #22 on: 18 July 2005, 13:17 »
The difference between a good helmet and a bad one can be life or death. Don't buy a second hand one.
Offline hc-animal
« Reply #23 on: 16 August 2005, 18:09 »
camber angles are critical. around about half a degree is good for the road but for all out trackday fun you want 3-4 degree negative. but you try getting your local tyre shop to adjust the camber. after adjusting the camber be sure to readjust the toe as well making it straight ahead
Offline Organisys
  • Old and Slow...
« Reply #24 on: 17 August 2005, 13:22 »
My mechanic runs his Mk2 with a vr6 engine conversion at 5 degrees negative camber for track days, to counter act the weight of the bigger lump and improve grip / reduce under steer.
Offline GTI EDITION (aka LTD)
« Reply #25 on: 18 August 2005, 21:07 »
I adjusted mine to 3 degrees for trackdays, but like a tw@t I left it a bit too long before I readjusted it as it handled so well  :cool:
( its amazing how quickly tyres get goosed  :rolleyes:)
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=topn&cat=19378
Does my arse look TOO BIG (to fit) in this (forum).... or was it something I said ?
Fielder5757
« Reply #26 on: 18 August 2005, 22:17 »
Hmmm while this threads up i might as well post my track day progress.....
acctually theres no progress, The cars been neglected latly (badly) becuase ive been buisy with my new job. But coilovers are a comming ;)
mix
« Reply #27 on: 18 August 2005, 22:27 »
As in the verge :wink:
« Reply #28 on: 18 August 2005, 22:34 »
Well most peeps on here like there V Dubs ' DOWN IN THE WEEDS '  :grin: :grin:
mix
« Reply #29 on: 19 August 2005, 21:35 »
^^but a mr veedub16v took his car for a drive along the verge to miss a cyclist riding the wrong way down a one way road, and consequently said hello to the sign post :undecided:
Dunno if he has posted pics or anything up
