Author Topic: ACC worth it or not  (Read 6766 times)
Offline Whiteshirt
Re: ACC worth it or not
« Reply #20 on: 26 March 2012, 09:17 »
Had it on my Audi TT. I thought it was a bit gimmicky.
So not bothered this time around.
5door GTi white manual, Performance Pack  ACC  Discover Nav Pro  Winter Pack   Dynaudio  Pan roof   Park assist  Service Pack
All gone since 2001 some forgotten. Porsche Boxster/Cooper S Works/Merc CLK/Gti MK5/ Audi TT/ GTi Ed 30/BMW 123d/Ford Kuga/GTi Ed 35. All new all lost money, some a lot more than others.(except edition 35 which lost nothing  in 9 months other than its wings, suspension, roof etc))
Offline gizzywizzy
« Reply #21 on: 26 March 2012, 09:27 »
If you don't have it you can't possibly comment on it!!
It does make quite a difference to the ride but obviously that depends on how you drive your car.
I wouldn't spec a car without it TBH.
Offline Edi35
« Reply #22 on: 26 March 2012, 09:35 »
Not worth it IMO. I have used this on demo cars and most of my trips take in B roads, dual carriage ways and town all in the same trip so I ended up switching the ACC to suit which didnt work out for me.
I have std suspension and run 19" and the ride is firm (its a GTI) and have noticed on poor roads and it can be slightly crashy compared to 18" but the steering and turn in are better than 18". I would consider this if ACC worked automatically and firmed up the suspension when pressing on e.g. when you need it. It does make a difference and if this is must then go for it but its not for me.
Current: GTI Edition 35 Candy White 5dr DSG 19" Glendale, RCD510+DAB, Dynaudio, Storage Pack, Parking Sensors
Gone: Edition 35, GTI Mk6, Edition 30, GTI Mk4, GTI Mk3, GTI Mk2 and my favourite the UR quattro
For those that dont know DSG is an electronically controlled dual-clutch multiple-shaft manual gearbox
Offline Ess_Three
« Reply #23 on: 26 March 2012, 09:42 »
It does.
It measures acceleration force, lean angles and braking force to automatically adjust the damping within a set range.
http://www.my-gti.com/2653/volkswagen-dcc-adaptive-chassis-control-design-and-function
But you can force it into softer or harder base settings for the upper and lower limits of the damping control.
..but gaining motorcycles.
Offline Edi35
« Reply #24 on: 26 March 2012, 09:59 »
It does.
Interesting thanks. As you say adjusts the damping within a set range, I wish that range included Comfort and Sport as you wouldnt need to switch it at all and that is the functionality which would tempt me to add this as an extra, it must be possible with all these sensors fitted?
Offline Ess_Three
« Reply #25 on: 26 March 2012, 10:23 »
I agree...but then I guess it wouldn't know if you wanted the car to be soft, or hard, or in the middle, so I can see the point of the selections.
What's not clear, is if the damping maps overlap, so could the controller select a setting as hard as the upper end of 'Sport' if the selection was 'Normal'? I don't know.
Plus, the controller adjusts the weighting of the steering assistance.
I'm hoping someone will finally crack the coding so you can adjust the damping ranges and steering weighting outwith the standard modes - personally, I can live with the damping, but would like the steering response of 'Sport' when in 'Dynamic'.
Offline Pinky 1959
« Reply #26 on: 26 March 2012, 20:07 »
Thanks for all the replies swimbo is considering changing her car and I would like acc but its quite pricey and the standard car may be to bumpy on rough roads for her , A full days test drive soon hopefully to try it out .
