Author Topic: Cleaning the exhaust tips....  (Read 4127 times)
Offline sharki786
  • GOT BOOST??
Re: Cleaning the exhaust tips....
« Reply #10 on: 03 April 2012, 14:44 »
i was just thinking about asking whats better to use then autosol. As i have a few black spots on the tips and no matter what i do it just wont budge. I leave autosol on for about 5-10mins and then use a tooth brush. But now i can see your using wire wool but what grade is it?
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Jimble
« Reply #11 on: 03 April 2012, 17:30 »
It's 00 grade wire wool mate.
http://www.cleanyourcar.co.uk/accessories/-00-wire-wool/prod_377.html
But tbf your not really using autosol properly, it's an abrasive paste so using a toothbrush is a bit pointless, get yourself a microfibre or even a piece of rag, put a little on the rag and then get sime elbow grease into it! You may not need wire wool. :wink:
Offline sharki786
  • GOT BOOST??
« Reply #12 on: 03 April 2012, 23:45 »
sweet mate. il try that :wink:
*****MK4 GTI T*****
Offline Stokie Mac
« Reply #13 on: 06 April 2012, 15:10 »
Will try it this way myself as i use a Toothbrush aswell..
Offline john a
« Reply #14 on: 08 April 2012, 22:32 »
You can pick up bags of 00 wire wool dead cheap in most places (B&Q, Screwfix, Toolstation, etc). I have used it in conjunction with Autosol and also with the Britemax Metal Twins. The inside of the tailpipes on mine is pretty baked on and I am thinking I may have to take varying degrees of flap wheel to it to clean them up before going at them again with the Britemax.
Offline Murrayedition35
« Reply #15 on: 08 April 2012, 23:21 »
I used the fine wool and it works a treat....
