Author Topic: Car Jack Requirements / Advice  (Read 6665 times)
Offline Rhyso
Re: Car Jack Requirements / Advice
« Reply #10 on: 25 March 2012, 20:51 »
If you are only changing the wheels and wont be doing anything else than the one in the boot is fine, that is what it is desgined for, changing a wheel. When its jacked up just put the wheel that is ready to go on underneath the chassis near the wheel arch so if the jack goes the car won't hit the floor. I am sure the jack wouldn't go, espeically as it takes less than 5min to change a wheel...Don't waste your money.
 :shocked: :shocked:
A decent trolley jack is about £40 which is well worth the money if you're going to be using it at least twice a year.
I've witnessed first hand the 'widow maker' collapsing; thankfully Adam (on here) wasn't hurt!!  Nearly made a mess of the side skirts mind.......
Meh  :lipsrsealed:
Spend the £40 get a trolley jack. Rhyso is right...I'll go crawl back under my rock  :rolleyes:
 :kiss:
Offline AudiA8Quattro
« Reply #11 on: 25 March 2012, 22:23 »
Yep buy a trolley jack, worth every penny  :rolleyes:
Offline Mr_F
« Reply #12 on: 26 March 2012, 07:43 »
Well as the sun was out, I wanted to go play, so went with the Widowmaker rather than go to the shops, managed all four wheels, mounted correctly but did manage to break a 1.5" thick piece of Honister slate in the process.  Made my heart skip a beat when it went.  Nicer jack needed!
Summers wheels on and Scraping Ice off the window this morning, typical!!!!
Thanks guys, you're all awesome!
61 Plate GTD 5dr, Shadow Blue, 18" Charleston's, Flat Tyre Indicator, Cruise Control, Bi-xenon (With Dynamic Curve), Storage Pack, Winter Pack and RCD 510.
« Reply #13 on: 26 March 2012, 16:43 »
You can pick up a trolley jack new for as little as £20 on ebay, there really is no excuse!  :grin:
VW BUSH
« Reply #14 on: 29 March 2012, 21:00 »
2 ton compact jack with case from machine mart £25 :cool:
Offline h8v
« Reply #15 on: 30 March 2012, 07:54 »
......and www.toolstation.com cheapest 2 tonne trolley jack item No. 12136 at £21.90 including delivery. :laugh:
h8v
Offline Mr Blue
« Reply #16 on: 02 April 2012, 11:42 »
Buy cheap buy twice.
Get a good 3 tonne jack.
Offline vaughn
  • now team wagon, and team grumpy trainee
« Reply #17 on: 02 April 2012, 14:15 »
he`s got a mk6 not a mk3 :grin:
57 plate black 5dr ed30, 1969 bay window devon camper. thats all for now folks, hopefully picking up a wagon tomoz
Offline dom
  • Back in a Mk4
« Reply #18 on: 02 April 2012, 16:10 »
Just to echo what Rhyso said, the widdow maker that came with my Mk4 has collapsed twice now....luckily both times it was whilst I was lifting the car so the wheels were still on. I have seen another one collapse as well, it's not worth the risk :undecided:
« Reply #19 on: 03 April 2012, 15:34 »
3 ton is a bit overkill. A good quality 2 ton is good enough, or a cheap one for occasional use!
