Author Topic: horrible vibrations and noise  (Read 11146 times)
Gavv8
Re: horrible vibrations and noise
« Reply #20 on: 09 April 2012, 00:35 »
still think it's the exhaust manifold...
Offline stow1985
  • 'when im cleaning winders'
« Reply #21 on: 09 April 2012, 00:40 »
1 problem found the heat guard/cover was loose so rattling when rev'd so clamped that.
still vibrating tho.. havent given up yet  :grin:
I've had this before, made my heart sink  :grin:
Offline shelaghmk3gti
« Reply #22 on: 09 April 2012, 02:03 »
ok, can you tell me why you think that, where the thing is and what could be possiby wrong with it (( might save me several notes if i least look like i knw what im talking about))
so step by step please lol x
yes stow i was very excited when i rev'd and no noise.. till it moved :(
Gavv8
« Reply #23 on: 09 April 2012, 08:59 »
No, i'm wrong if its totally normal when revved at standstill then it can't be the manifold, my thought process was based on it sounding 'like a diesel' and having had head work done recently.
i've heard cracked/damaged and badly/wrongly fitted exhaust manifolds and they can be very quiet at tickover because its not under so much pressure but will sound like an old tractor when revved whereas a sick gearbox will usually whine and be difficult to use so to be clattering like a diesel it would have to be on its last legs.
I know you've said it sounds like its coming from the gearbox but it can be deceptive if you can only hear it from the driving seat.
Offline javalin
« Reply #24 on: 09 April 2012, 09:04 »
my gearbox whines,  but its a definate whine and sounds like its from the gearbox.
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
« Reply #25 on: 09 April 2012, 11:02 »
ah i see :(
well thanks for taking the time to explain anyway.. im tempted to put it down to 'just a noise that it makes' but thats not good enough
ok, gonna go and see 3 diff garages tomorrow and see what the common opinion is.. then of course bug you again for a cheap fix :lol:
im adament thats its really there and im not imagining it  :nerd:
forgot to say that when it was up on the ramps ( shes amazinly clean underneath!) the 'oil leak' that i sa was deffo the mess laft behind after the head was done... so infact its not leaking oil at all
would the cat being loose cause it to vibrate?
« Last Edit: 09 April 2012, 11:36 by shelaghmk3gti »
Gavv8
« Reply #26 on: 09 April 2012, 12:38 »
If the cat has broken up inside it could cause rattling and extra noise when its revved.
« Reply #27 on: 09 April 2012, 12:59 »
right what i need is a link to somewhere where i can view the whole engine ( named parts)  :embarassed:
pretty please
Gavv8
« Reply #28 on: 09 April 2012, 14:19 »
If you look in the mk3 maintenance section there are lots of threads and pictures of the various nether regions of the mk3.
« Reply #29 on: 09 April 2012, 18:25 »
have spent hours looking through that.. cant find what im after...although its very very good!
ill pop and get a haynes tomorrow..i left my last one in the boot of the old golf  :sad:
