Author Topic: horrible vibrations and noise  (Read 11149 times)
Offline shelaghmk3gti
« on: 21 March 2012, 06:58 »
its under the bonnet, happens when driving not idiling and just noticed when i went for milk that it dont happen when clutch is dipped..
cant really describe the noise but its like a diesel :/
any ideas?
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: horrible vibrations and noise
« Reply #1 on: 21 March 2012, 07:07 »
When I first read the title I thought you were referring to something that had slipped out of your "private collection"  :rolleyes:
« Reply #2 on: 21 March 2012, 07:11 »
hahahaha!!
 i can assure you that theres nothing in my 'private collection' that sounds like a diesel  :grin:
Offline wakeskater
  • H20 PHW MK3 16V DAILY ,,,MK1 16V PROJECT,,
« Reply #3 on: 21 March 2012, 08:33 »
lmao :grin: :grin:
Offline javalin
« Reply #4 on: 21 March 2012, 10:05 »
sounds like a misfire.  It is worse when > idle?
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline WadGTI
  • Golf GTI'er
« Reply #5 on: 22 March 2012, 12:44 »
I have the same - its the thrust bearing on mines.
« Reply #6 on: 30 March 2012, 15:17 »
have changed the plugs today.. its a bit better overall but the vibration wont stop :( gonna take it in on monday and see what it is..seriously annoying me.. sounds lovely when idling
Offline WeekendMechanic
  • Golf MK3 GTD
« Reply #7 on: 30 March 2012, 16:15 »
Like WadGTI its coming form the gearbox.
Offline Seanl
« Reply #8 on: 30 March 2012, 20:38 »
Seriously not having much luck with this one are you Shelagh.  :sad:
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #9 on: 30 March 2012, 21:27 »
If it totally goes when you dis-engage the clutch, its most likely the gearbox main-shaft or counter-shaft end bearings if it sounds like that.
To be honest, if its suddenly gone and gone that bad,  i would suspect there is an underlying problem such as an oil leak etc..
Unlikely to be the thrust bearing, that will be quiet when the clutch is not depressed and worse when it is depressed, due to it being under pressure in contact with the diaphragm springs, common misconception, or people refusing to believe their gearbox is nackerd  :grin:
I would advise you to change or at least check the gearbox oil,  remove the upper filler plug and fill it until it pours out,  if it took more than half a litre  its almost certainly lost oil causing the issue.   If the level is ok,  Run the engine in netueral and rev it, listen down close to the gearbox for rumbling/clicking noises, that will pretty much confirm it.
Could possibly be a faulty clutch plate falling apart, but very unlikely.
This is based on the info you have given so far so could be other things too but more info would be needed to go down any other route at this stage.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
