Author Topic: my catch can install (pic heavy)  (Read 5616 times)
Offline cullygti
Re: my catch can install (pic heavy)
« Reply #20 on: 19 March 2012, 22:56 »
ebay mate it is not oil or fuel specific so as said prob wont last as long but it was cheap does what it is suppose to so that will do till i can afford some tidy stuff  :laugh: i had it a lot cheaper than this tho as it was on offer
http://www.ebay.co.uk/itm/1-Metre-Silicone-Straight-Long-Hose-Silicon-Rubber-Coolant-Radiator-Pipe-Water-/330651132313?pt=UK_DIY_Materials_Plumbing_MJ&var=&hash=item7dbd775d8d
« Last Edit: 19 March 2012, 22:59 by cullygti »
Offline rench
« Reply #21 on: 19 March 2012, 23:05 »
how many meters you use? ive done mine with standard silicone so need to change it and move catch can.
Offline cullygti
« Reply #22 on: 19 March 2012, 23:07 »
2 metres of 19mm mate you may need a different size to mine tho
Offline rench
« Reply #23 on: 19 March 2012, 23:09 »
mines 19mm booth inlet and outlet ill sort 2 meteres out then
Offline Dan_GTi8v
« Reply #24 on: 19 March 2012, 23:53 »
where did you get the 19mm inlets from?
Offline Big Tone
« Reply #25 on: 20 March 2012, 07:15 »
He had them custom made, I am in the process of making some up, take it you are after some? Need to start a list of people who want them, then I can order the material.
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
Offline rio_gti
« Reply #26 on: 20 March 2012, 11:38 »
copied from  #List of names - Custom made 19mm catch can fittings#
I'm interested in a pair made to the same spec as cullygti's.
I have the same catch can but I have decided to mod mine slightly, I've stretched out a steel wire scourer and dropped it into the can. I've also got some copper plumbing pipe (12 or 15mm I will check when I get home) and bent it slightly and also drilled a couple of holes down the side. I am going to epoxy that to the inside of the inlet fitting so that the gasses have to pass through the scourer baffle first. Thats my cheapo bodge to copy the saikou michi internals. http://www.saikoumichi.com/OCC_explanation.htm
Would you be able to lengthen the thread of one of the fittings or possibly machine it so the copper pipe can slide over or into the fitting?
dunno if a scourer would break up, i had one on the side which was wet and it ended up rusting and falling apart and as there is almost 90% water when catch tank is emptied i think it would rust.....
would a stainless steel one not rust with the oil/water mix  :undecided:
Offline Jin_C
« Reply #27 on: 20 March 2012, 11:44 »
Thats what I was thinking so I went for the stainless steel thick wire type
http://www.amazon.co.uk/Pack-Heavy-Stainless-Steel-Scourers/dp/B003UP0UZW/ref=sr_1_6?ie=UTF8&qid=1332243632&sr=8-6
Being stainless steel, it shouldn't rust. In theory! I'm guessing it wont be as good quality s/s as an exhaust system but even then it will last at least 6 months. They're cheap enough to replace nearly as often as I would empty out the can.
1.8T AGU, K03s, 007p, pipercross panel filter, G60 + VR6 clutch and flywheel, silicone TIP, decat + boost hoses, JOM coilovers
Offline rio_gti
« Reply #28 on: 20 March 2012, 11:45 »
its just the worry of it starting to break up and get sucked into the turbo causing boom boom!!!!
Offline cullygti
« Reply #29 on: 20 March 2012, 12:45 »
as the pieces are bigger on the scourer maybe epoxy resin some gauze to the inside of the inlets like this or maybe if you get a big enough piece of gauze line it right around the can and then put in the scourer something like this in the link as an example to line right around inside of can obviously you can find it a lot cheaper this is just an eg..
http://www.cooksongold.com/Jewellery-Tools/Stainless-Steel-Gauze-15cm-X-15cm-prcode-999-AFN&p=gs
« Last Edit: 20 March 2012, 12:48 by cullygti »
