Author Topic: oil usage  (Read 1663 times)
Offline james2
  • No scammers please.
Re: oil usage
« Reply #10 on: 15 March 2012, 00:06 »
mines on 96,000 miles . Intercooler is my oil cooler . :lipsrsealed: plus rocker cover leaks a bit .I also think the sumps leaking. I havnt checked my oil in  :undecided: , ill check it tomorrow .  :evil: im losing the touch of keeping my car mint . xbox 360 and beers have taken over.  :drool:  :embarassed: . I need a job (help) . Saying that ,i get paid £300 every 2 weeks for doing jake.  :nerd: i love beging on the bank .  :rolleyes:  :smiley: :smiley: :smiley:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline rockmonkey69
Re: oil usage
« Reply #11 on: 15 March 2012, 01:21 »
It all boils down to a combination of factors; not being run in properly from new and high mileage will take its tow. Most 1.8t will be loading oil through the valve stem seals and piston rings, my engine was using about 250ml every 400-500 miles and was on 150k. Upon removing the intake manifold there were signs of failing valve stem seals and this was the state of my piston before I cleaned it:
After
And of course the cylinder wall were glazed
After
There were signs of excessive wear on the piston rings and oil rings - all of which contribute to using oil! There was a slight drop in compression across all 4 cylinders and it's clear from the above photos this is expected.
Even the valve guides were caked in oil residue.
« Last Edit: 15 March 2012, 01:35 by rockmonkey69 »
Offline Big Tone
Re: oil usage
« Reply #12 on: 15 March 2012, 08:58 »
88k on mine, 52k of that in the lasy 3yrs, 5w40 fs quantum platinum, 100 miles a day, no smoke and dont use hardly anything, perhaps 1/4l every now and then. But thats with my ocd, I keep an eye on it always .
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
