Author Topic: Old Fart  (Read 26969 times)
Offline Roverdose
  • So long and thanks for all the fish!
Re: Old Fart
« Reply #50 on: 07 May 2012, 16:45 »
Well, been busy today, got the washer jets working for mot, and refitted the coil properly, other than that all i could do was bits n bobs as i didn't get cv boots in time, I've had a bad leak into the car, i checked the door membranes and...
my in car pool
Tell tale signs
rear door before
after
took the oportunity to grease up the window runners and clean out the holes for the water to drain out
Front door was the worst, only a couple of cm's at the top were still bonded
after
and a pic of one of my golden scrapyard finds!
Left to do: CV Boots, wire up a horn and tyres and she's ready for mot! Gonna do the other 2 doors even tho there's no leak for good measure if i have time! thanks for looking!
Gavv8
Re: Old Fart
« Reply #51 on: 07 May 2012, 16:57 »
There seems to be a spate of in car pools at the moment, must be the weather..good luck with the mot bud.
Offline Roverdose
Re: Old Fart
« Reply #52 on: 07 May 2012, 20:35 »
ta very much, it's hounding it down with rain here at the moment so gonna park the car nose downhill an see if it fills up again!
Offline Roverdose
Re: Old Fart
« Reply #53 on: 09 May 2012, 13:53 »
Still dry after a whole day and night of rain! AND i now have in my hand an MOT certificate!  :laugh:
I got busy yesterday and did
2x CV boots
Re wired the horn
2 Exhaust hangars
Oil + Filter
Had the 2 front tyres fitted
Got Advisories for:
Slight play in rear wheel bearings
Inner lip of NSF Wheel slightly buckled
Light corrosion on floorpan
Slight play on O/S Ball joint
So a bit more work to do but a RESULT! Pics to follow!
