Author Topic: removing dead pedal  (Read 876 times)
Offline symsymma
  • AGU POWER,drive it like u stole it!!!
removing dead pedal
« on: 07 March 2012, 18:36 »
How do you remove dead pedal,got a bling cover i want to fit.take it you remove front of centre console to get to fixings :undecided:
1.8T AGU 203bhp & 233lb/ft Rtech stage 1 custom remap,18"dezentz rims,lowered 40mm shocks n springs,whiteline 24mm adj rear arb,lcr axle bushes,polybushed arb,modified front bumper & valences,depo projector headlights,delocked,wrapped interior&bora gear knob,forge boost & coolant hoses,forge tip,forge 007p,samco vac hoses,simota aeroform cai,saiko michi catch can,deleted pcv system,r32 dogbone,miltek lg bore down pipe & sports cat/non res anni style system.
Offline gm8
Re: removing dead pedal
« Reply #1 on: 07 March 2012, 18:43 »
i never removed mine when fitting this , self tapping screws.
Offline symsymma
« Reply #2 on: 07 March 2012, 18:51 »
Yea did think about self tappers.was ur plate countersunk or did you use them screw cup things?
Offline gm8
« Reply #3 on: 07 March 2012, 18:57 »
came with screw cup things
Offline symsymma
« Reply #4 on: 07 March 2012, 19:24 »
Yea might use them cups but i might counersink the plate so its all flush.well at least the bottom hole neways.
