Author Topic: FK AK street coilovers  (Read 4026 times)
Offline cullygti
Re: FK AK street coilovers
« Reply #10 on: 06 March 2012, 18:08 »
dpm were doing a deal on the joms for £150 or there abouts cant go wrong for that money and you get a 2 year warranty with the joms  :cool: oh and i also have joms with no probs
Offline mcgee9t2
« Reply #11 on: 06 March 2012, 19:53 »
i have fk ak. no probz.
there basically the same coilovers, iirc there even made in the same factory just a different spring put on.
Offline 1.6mk4GOLF16v
« Reply #12 on: 09 March 2012, 17:48 »
which are better quality out of the 2?
any idea what the failure rate on each is?
i can get both kits for £155 each but im unsure which to go for  :undecided:
1.6 16v AZD
RS8s 225/35/19
Full powerflow decat exhaust
Blanked EGR
Pipercross panel filter
watch this space for the rest...
Offline Broomers-GTi
  • 1.8T 2002 AUM
« Reply #13 on: 09 March 2012, 18:31 »
155squid?? get in thts good  :tongue:
Offline mcgee9t2
« Reply #14 on: 10 March 2012, 13:08 »
ide go for fk just for the fact its more of a "brand" than jom
jockgti
« Reply #15 on: 11 March 2012, 11:25 »
see after fitting my fk's and using 5mm spacers all round i'm getting rubbing on the n/s rear tire just on the edge,is the rear axle offset slightly? and if yes by how much,and i'm not sure about joms but the fk's are solid not much give in them
« Reply #16 on: 14 March 2012, 01:52 »
will i need spacers with 19" rims?
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
Offline mk3tony
« Reply #17 on: 14 March 2012, 12:54 »
i'm on 19's with joms, 5mm spacers front et 35 8.5j with 215/35 rubber. Its close.
Regarding failure rate, DPM, Awesome and Venom all said FK failed more than JOM. Jom had a 2 year warranty though dpm whereas Fk was only 1. FK is a better ride than jom but warranty and reliability so trusted the dealers.
2001 1.8T AUM - Rtech Spec 1 Custom Map, Catch Can, Cone Filter, 209bhp 237 lb/ft, SuperPro Wishbone and Rear Beam Bushes, Jom Coilovers, 19" BBS CH Reps
Offline cullygti
« Reply #18 on: 14 March 2012, 12:56 »
+1 2 year warranty through dpm on the jom's is a good deal and dpm are pretty good if they brake dpm will replace them  :smiley:
« Reply #19 on: 20 March 2012, 03:23 »
i got 19" audi rims on mine, with 225 35 rubbers on em but where or how do i found out what "et 35 8.5j" they are?
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
