Author Topic: best tool for rounded bolt removal  (Read 2139 times)
Offline mcgee9t2
Re: best tool for rounded bolt removal
« Reply #10 on: 03 March 2012, 15:44 »
Yeh seen that one in halfords . Are they any gud . Think I am gunna get this one tbh
  http://item.mobileweb.ebay.com/viewitem?itemId=220865332593&kw=220865332593
it worked for me and a mate, however that was on locking wheel nuts, not sure how good it would be on a normal nut/ if it would be small enough for a normal nut.
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #12 on: 03 March 2012, 16:14 »
irwin bolt extractors, they are the tits!
http://www.amazon.co.uk/s/?ie=UTF8&keywords=irwin+bolt+grip+remover&tag=googhydr-21&index=diy&hvadid=9533842640&hvpos=1t1&hvexid=&hvnetw=g&hvrand=466464470554179987&hvpone=&hvptwo=&hvqmt=b&ref=pd_sl_5sxifpi6e4_b
Ohh they look sweet!
Those stud extractors you first linked up mate, drill a small hole into the wheel bolt then screw that in! Good luck...Put up a photo of your efforts after!
Offline ReadieeVTS
« Reply #13 on: 03 March 2012, 18:05 »
Mig Weld a Bolt onto the bugger, I had the same and this worked a Treat for me!
Offline stevelfc
« Reply #14 on: 03 March 2012, 21:07 »
Tried that sockets just slipping bolt is that rounded
Do these work  :undecided:
http://www.toolstation.com/m/part.html?p=51010
no m8 you need irwin bolt extractors  about £20 from machine mart
« Last Edit: 03 March 2012, 21:08 by stevelfc »
Offline symsymma
  • AGU POWER,drive it like u stole it!!!
« Reply #15 on: 03 March 2012, 21:40 »
these are ok depending on how tight the bolt is and the hardness of the bolt itself ive broken these extractors before trying to remove bolts.if you get these drill pilot hole deep!
1.8T AGU 203bhp & 233lb/ft Rtech stage 1 custom remap,18"dezentz rims,lowered 40mm shocks n springs,whiteline 24mm adj rear arb,lcr axle bushes,polybushed arb,modified front bumper & valences,depo projector headlights,delocked,wrapped interior&bora gear knob,forge boost & coolant hoses,forge tip,forge 007p,samco vac hoses,simota aeroform cai,saiko michi catch can,deleted pcv system,r32 dogbone,miltek lg bore down pipe & sports cat/non res anni style system.
