Author Topic: Mk2 GTI MFA bulb and 'Hour Button' not working  (Read 7441 times)
Offline pigbladder
Re: Mk2 GTI MFA bulb and 'Hour Button' not working
« Reply #10 on: 04 March 2012, 18:44 »
for the hour button...clocks need to come apart and then take off the mfa display , i use a fibre glass cleaning stick to clean up the contacts that the button touches
all the ones ive done have worked 100% after a clean up
Offline dragonfly
« Reply #11 on: 04 March 2012, 19:03 »
Another quick one, I noticed on fan speed 1, it's abit noisy on start up and when I switch it back to 0 and it slows down, it is noisy. Can I just remove that grommet under the cubby hole on the passenger side and spray some White grease up? Didn't want to just do it and break something.
Thanks for your help, much appreciated
Remove the passenger side lower tray, disconnect the heater and drop it down to remove.  Once out you can spray the motor.  Very common on mk2s!
Offline scott-o
« Reply #12 on: 04 March 2012, 19:46 »
Thanks pigbladder, something to do at some point in the future for sure. For now it tells me the right time though but it's good to know the original can probably be sorted!
Dragonfly, thanks for that, I have just been in the garage and have taken it out and taken the motor and White fan out of it's housing. Is it just a case of getting some ptfe White grease or copper grease and spraying it in and around each end? I'll have to go and buy some tomorrow. Just going to clean the fan now before top gear!
Cheers for all the help, this forum has been great for it so far. You are all helping a mk2 virgin get some confidence to work on the car :)
Offline dragonfly
« Reply #13 on: 05 March 2012, 18:38 »
Yes just give the motor a squirt or 2 of grease and gently spin it by hand.  Don't over do it and grease everywhere.
The noise will eventually return.
Offline scott-o
« Reply #14 on: 05 March 2012, 21:48 »
All back together now and it's nice and quiet, cheers for the help
Offline Tatboy83
« Reply #15 on: 10 April 2013, 08:41 »
Do u still make the bulbs mate ?
Offline Tatboy83
« Reply #16 on: 11 April 2013, 15:54 »
I make an LED version of these, brighter than the stock bulbs & better light distribution...
And fitted...
. Are u still making them mate?
Offline Adam
« Reply #17 on: 11 April 2013, 17:37 »
I need a set!  :cool:
Down Hill From Here.
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #18 on: 11 April 2013, 18:56 »
Have a look on Ebay, he used to sell them on there.
I see he hasn't been on here since January.
For More Info Click To See;
Offline Tatboy83
« Reply #19 on: 11 April 2013, 23:02 »
had a look on e bay but they ain't as good as what he made ;(
