Author Topic: settle an argument!!  (Read 2806 times)
Offline Khare
  • The bear that khares
Re: settle an argument!!
« Reply #10 on: 29 February 2012, 13:04 »
To safely charge a battery in situe, I would simply remove the positive lead for the car first.
Stories of blowing stuff up when jumping are usually the result of bad lead positioning.  You shouldn't really connect both batteries directly together.  The safer way to do it is Positive to Positive, and the negative from the supply car should be connected to the body of the flat car, not the battery.
Yup, that's how I've always done it.
Offline R32UK
« Reply #11 on: 29 February 2012, 13:22 »
call the aa/rac. always worked for me
Offline justalex81
« Reply #12 on: 29 February 2012, 15:09 »
exactly what i did
Offline madmanluke
« Reply #13 on: 29 February 2012, 15:25 »
What difference does it make if you put the negative to a ground on the chassis or the battery? The chassis is grounded to the battery, making a circuit. It wont make a difference where you put it.
Offline Ant1981
  • Feed me, prod me
« Reply #14 on: 29 February 2012, 18:11 »
Electrically, there isn't any difference.
'09 Kawasaki Ninja ZX-6R
Offline MK3GTI_16Valve
« Reply #15 on: 29 February 2012, 19:50 »
Not sure what difference this makes either...the body to the negative will be more or less 0 ohms, essentially same point
Offline danny_p
« Reply #16 on: 29 February 2012, 20:34 »
usally put jump lead on to some engine bracket.
some cars really really hate being bump started    pudgits and sh!torens are famous for that one.
not met anything yet that wont jump start some arnt so straight forward tho, usally fnd it better to connect them up and leave 10 mins  dont even need the car doing the jumping to be running
all the VW's have gone bar 1.
Offline Ant1981
  • Feed me, prod me
« Reply #17 on: 29 February 2012, 20:37 »
And with the cars not liking being jump started, can't see the difference in connecting jump leads to the battery and starting the car, as all the car will see is a 12v battery that'll start it.
Gavv8
« Reply #18 on: 29 February 2012, 20:43 »
So what he's saying is that every time the battery has to be changed, the electrics and the gearbox have to be changed/repaired?  :laugh:
It is a vauxhall................
Offline droofer
« Reply #19 on: 29 February 2012, 20:44 »
on my peugeot expert van the battery went flat i charged it up still in the vehicle went to start it and it blew the ecu up. will never buy french again. this was when i was about to sell it for a good price and i lost the sale. i'm about £1500 down because of it
 :sad: - ive heard of this happening on a bmw too.very costly it was also.
