haldex controller on the mk4 makes it a 50/50 split of torque, if your system isnt cared for then it will kill it quickly (usually only gets 20% of the power)you want a proper 4wd then get an a4 quattro, thats a full time 4wd, and if you pull the fuse for the haldex then you have rwd
Quote from: houston on 28 February 2012, 18:30haldex controller on the mk4 makes it a 50/50 split of torque, if your system isnt cared for then it will kill it quickly (usually only gets 20% of the power)you want a proper 4wd then get an a4 quattro, thats a full time 4wd, and if you pull the fuse for the haldex then you have rwdWould have thought they would use same 4wd platform throughout.. Will keep an a4Quattro on the list then
