Author Topic: AGU MAF fault/overboosting when maf connected???? HELP  (Read 3102 times)
Offline bigmarky
« on: 27 February 2012, 19:27 »
Right
Posted on here few days ago regarding my AGU having running problems - http://www.golfgtiforum.co.uk/index.php?topic=223147.0
Basically ive only owned the car a few weeks, when i started running funny i asked on here and tried cleaning out the throttle body, which i dod fine, at this point the maf had been unplugged, i assumed it had just come out with me working in the engine bay and reconected it. The next day the car stared massively overboosting over 35 psi etc, i again asked on the forum and thankfully one of the guys stuck it on his vag.com, to get the readings of a faulty MAF and lambda sensor. Today i changed the MAF and tested the car, and its no different, a nice £90 down the drain  :cry: then just out of interest i unpugged the MAF again and ran the car up the road to find it boosts and normal 15-18psi etc.
Can anyone please please help starting to get a tad pissed off now lol.
Tornado Red, 99 AGU, full milltek, K & N, forge007p, 18\" A8 in custom Matt Black with Anthracite inserts, Custom remap, 22psi boost, HID\'s, full led\'s, bodykit.
Offline xxChrisxx
Re: AGU MAF fault/overboosting when maf connected???? HELP
« Reply #1 on: 27 February 2012, 19:37 »
Whats happening is that when you unplug the MAF the ECU is reverting to a default map. So everything ignores what the sensors are saying and just does what it's programmed to do with no instructions.
First things to do are free:
Check for split pipes.
Clean TB (done)
Can't think of any others that are relevant in this case.
I'd still suspect that the controller for the waste-gate is buggered. N75 I think.
What this means is that when you are getting upto a boost level, some exhaust gas isn't bypassing the turbine, causing an overboost.
Offline bigmarky
« Reply #2 on: 27 February 2012, 19:39 »
We checked for split hoses when we did the vag.com yesterday and nothing was evident.
Offline topher
  • Administrator
  • fully functioning
« Reply #3 on: 27 February 2012, 19:43 »
check the actuator vac hose again. remove it completely if you have to, it can be hard to spot splits.
Offline stevelfc
« Reply #4 on: 27 February 2012, 19:51 »
faulty new maf or have they sold you the right one for your car check part numbers on old and new .
Offline bigmarky
« Reply #5 on: 27 February 2012, 21:05 »
Just checked all pipes/hoses connections etc, took the dv off and put it back on, unplugged and replugged the new maf a couple of times etc and took it for a run, its now hitting and staying at 22 psi only went a mile down the road and back though. Thoughts???/
Offline jonnyturbo
« Reply #6 on: 27 February 2012, 21:13 »
Yep me and Mark checked all the pipes inc pcv system and all seemed fine . But like toph says take some of the pipes off to check for splits .
Offline james2
  • No scammers please.
« Reply #7 on: 28 February 2012, 02:13 »
you will easy see a leaking boost pipe, it will have oil on it. Forget the maf,as its new.
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline james2
« Reply #8 on: 28 February 2012, 02:17 »
bloody AGU  dont show all fault codes.  :wink:
Offline bigmarky
« Reply #9 on: 28 February 2012, 06:00 »
What is the large 90 degree pipe just at the back of the engine bay behind the block to the right of the turbo and left of the intake pipe comes up and bends left into the metal pipe roughly about 3" diameter that runs at the back of the head all above the turbo (I'm no mechanic lol) ???
