Author Topic: timing belt  (Read 7101 times)
Offline weejockvw
timing belt
« on: 26 February 2012, 19:09 »
Has the mk6 got a timing belt or a chain and when do they get changed
Offline Snoopy
  • Moderator
  • Geoff.
Re: timing belt
« Reply #1 on: 26 February 2012, 21:08 »
Mk6 GTI has a chain
mk6 edition 35 has a belt
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline squirrelGTi
Re: timing belt
« Reply #2 on: 27 February 2012, 09:18 »
Really the GTi has Chain?
So i guess the R has Belt as well then?
Gone GTi | 3dr | Manual | Carbon Grey | Xenons | Monza 18's | RCD 510 |Rear Camera | Winter Pack.
Offline Keithuk
Re: timing belt
« Reply #3 on: 27 February 2012, 12:54 »
Yes the GTI has a chain.
Strange you can't add pictures directly, poor forum.
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline Snoopy
  • Moderator
  • Geoff.
Re: timing belt
« Reply #4 on: 27 February 2012, 17:32 »
Yes r has belt
Mk6 GTI  &  Mk1 GTI
Offline weejockvw
Re: timing belt
« Reply #5 on: 27 February 2012, 19:20 »
so how often do you change the timing chain
Offline Snoopy
  • Moderator
  • Geoff.
Re: timing belt
« Reply #6 on: 27 February 2012, 22:46 »
It's normally designed to last the life of the engine. Sometimes they can get rattles at over 100,000 miles I cannot remember what vw quote in the engine document off the top of my head but its prob in the.maintenance section as.a.pdf
« Last Edit: 27 February 2012, 22:49 by Snoopy »
Mk6 GTI  &  Mk1 GTI
Offline dan2252
Re: timing belt
« Reply #7 on: 27 February 2012, 23:06 »
vw say they will last the life of the engine chains. but since ive worked for vw in 2 years weve changed a fair few now to be fair
MK4 golf 1.8 turbo agu :)
Offline Snoopy
  • Moderator
  • Geoff.
Re: timing belt
« Reply #8 on: 28 February 2012, 23:03 »
What other engines do vw do that have a full chain that you have changed due to ware? Or are you talking about the 888 engine waring chains out very quickly?
« Last Edit: 29 February 2012, 18:29 by Snoopy »
Mk6 GTI  &  Mk1 GTI
Offline topher
  • Administrator
  • fully functioning
Re: timing belt
« Reply #9 on: 29 February 2012, 00:42 »
i'd be shocked if the mk6 chains were failing already.. most repairs i hear of are R32 or older VR6
