Golf mk4
Wazzzer
ChRome inlet manifold
Topic: ChRome inlet manifold (Read 3485 times)
navmk4gti
Forum addict
Re: ChRome inlet manifold
Reply #10 on:
26 February 2012, 22:50 »
oh right ok.. i will use hammerite tho incase.. will 500ml do it? want to do it blue same as silicone pipe colour if can find it
Website:
https://www.theonestopledshop.com/
jockgti
Guest
Reply #11 on:
26 February 2012, 22:59 »
i used a 400ml can for both rocker cover and inlet mani,high temp for rocker cover and what was left on inlet to save money and get a good colour match
navmk4gti
Forum addict
Reply #12 on:
26 February 2012, 23:04 »
that is very nice
i take it you took out the manifold to paint the bottom of it too
Website:
jockgti
Guest
Reply #13 on:
26 February 2012, 23:12 »
yeah to make it high temp worthy it had to be baked in oven,so rocker and inlet both off,new gaskets on and a lot of head nipping from wife for stinking up the house with car parts cooking
rio_gti
"i'm not spending any money on it" Got a Hybrid!
Reply #14 on:
26 February 2012, 23:14 »
You actually used your home oven??!!!
2000 GTI 1.8t ARZ, S2000 filter, DSG intake, Forge 007 dv, Catch can, R-tech custom remap, 3" Supersize Silicone TIP, Powerflex dog bone, 'The Beast' FMIC, Ultimate delete, LCR fuel pump, 3" Turbo back, K03 hybrid, Ported Manifold, S3 injectors, 80mm maf = 280bhp 270lbft
jockgti
Guest
Reply #15 on:
26 February 2012, 23:20 »
yeah both bits fitted in fine,think it was 160 degrees for an hour or something
navmk4gti
Forum addict
Reply #16 on:
26 February 2012, 23:23 »
Quote from: jockgti on 26 February 2012, 23:20
thumbs up for using the oven
my mum would put me in there if i tried that tho so ill sit there with my wire brush instead
did you use the paint or spray can?
Website:
jockgti
Guest
Reply #17 on:
26 February 2012, 23:26 »
spray can,some e-tech stuff from ebay
Wayne
Sir Postalot
Reply #18 on:
27 February 2012, 08:09 »
Smoothrite is fine for a rocker cover does not need to be high temp paint
Ashmond
Money, b!tches And Boost
Reply #19 on:
27 February 2012, 10:18 »
Elbow grease! I quite like the crackle black paint you can buy in the can though. Much easier!
Last Edit: 27 February 2012, 10:23 by Ashmond
Golf mk4
Wazzzer
