Author Topic: jonrandom - Jon's TD05 16G  (Read 57777 times)
Offline markallen
  • AUM 1.8 20v Turbo 150bhp for now ;)
Re: jonrandom - Jon's TD05 16G
« Reply #30 on: 27 January 2013, 13:42 »
Envious of the Mk4 and now you rub salt into my wounds and get a Mk1.....I've decided I no longer like you   :tongue:
Golf Mk4 GTi Turbo, R32 front bumper, Lowered on ProSport Coilovers, Bora illuminated vents, Armrest, Heko wind deflectors, Aluminium vinyl trim.
Soon to be added, FMIC, 3" exhaust, Remap..oh and new turbo :(
Offline jonrandom
« Reply #31 on: 27 January 2013, 17:09 »
:laugh:  :laugh:
Offline jonrandom
« Reply #32 on: 01 February 2013, 23:11 »
Busy day.  :smiley:
Bought a random box of 2.5 inch bends off ebay as I though id make solid intercooler pipe work, reduce the risk of leaks as much as possible.
Striping off the old pipe work
Making it to keep it tucked in as much as possible to reduce the bumper bulge
Tacking together the other side
That side tacked together.
Removing the inlet manifold
Ready to fit this, sorry about some of the pictures
Bought another fuel rail to try and make the fpr as oem as poss. Dont know whether it will work but will soon find out.
Chopped up
Ready for welding
Welded
One tiny bit of weld over ran so need a hack saw blade just to sort that out so the nut will still spin freely, will sort that tomorrow.
Injectors out
New mani in
As far as I got today more tomorrow.  :smiley:
Offline jonrandom
« Reply #33 on: 02 February 2013, 16:58 »
Another busy day
sorted out the fpr so that fits
one side pipework welded and started spraying
inlet mani with throttle body fitted just standard one for now
Started on the otherside pipe work
didnt have a nut to fit the WMI as its tight thread  so cut it out of plate and tapped it
welded on
Pipe work finished and painted still need to bead it
Fitting the rail working out where things are going to go
Tomorrow will fit this  :smiley:
Offline xtetx
« Reply #34 on: 26 February 2013, 13:49 »
this is just nuts
Offline jonrandom
« Reply #35 on: 04 March 2013, 20:17 »
Cheers mate  :smiley:
Offline jonrandom
« Reply #36 on: 04 March 2013, 20:18 »
Well haven't done to much on this as been getting side tracked having to work on my work van which is still playing up :angry: Also been sorting bits for a future project.  :evil:
Welded the boss in the downpipe for the afr
Fitted it back on the car and fitted a lambda sensor for the afr, pulled all the wires through just need to fit gauge in the car.
Pipe work all finished welded little bits of metal on the end of each pipe instead of beading to stop any popping off. Water tested as well to make sure there were no leaks.
On the car
Inlet mani all fitted with pipe now connected need to find somewhere to fit the catch can now as it came off the old inlet before. Also want to try and tidy up the vac hoses so orderd some more and will try and hide them a bit better
Just need to replace the fuel filter then its ready to start her up again and make sure it all works  :smiley:
And fitted these looks much better I think
Offline jonrandom
« Reply #37 on: 06 March 2013, 20:19 »
Did a few bits today, started on moving the battery to the boot and setting the terminals in the bay.
I got a battery power cable from a bmw and fed it through a grommet so it came out by the ecu so I can then feed it down with all the other cables to keep it hidden.
Once the plastic casing goes back on it will be hidden
Used a couple of distribution boards for the terminals decided to keep the fuse box and screwed it all to the battery tray.
Earth terminal to the right, positive to the left, will make a cover to go over the lot.
Next hide the wire through the interior to the boot fit the battery and make a good earth. Shoulf free up some space in the bay.  :smiley:
Offline jonrandom
« Reply #38 on: 07 March 2013, 18:51 »
Cracked on with fitting the battery in the boot fixed in the tray.
Battery in
cover on
Will tack this bolt onto the boot for a good earth, hopefully should be ok?
Big fuse to keep things safe just needs a clean
Next started on fitting the gauge
Stripped it out which was a mission, not looking forward to putting it back together lol.
Took out the cup holder and cut a bit of SS to size and plasma cut out the holes
Welded on a couple of bits of metal on the back so could screw it in and its all good
Will wrap it, have decided in what yet. Now just need to get and fit the oil pressure/temp gauge
Offline jonrandom
« Reply #39 on: 13 March 2013, 21:15 »
This arrived, oil pressure and temp in one
Should look good I reckon.
Going to play around and get a good colour combo they come with different faces, ordered some vinyl wrap so hopefully can getting it looking good
Got this wkend free so will hopefully wire and plumb it all in and get it working.
I tided up the vac hoses a bit and now with the battery out of the way can fit the other filter.
So plans for the wkend wire everything back in, battery, gauges, EBC etc and make a cover for the old battery tray and make sure it all works!  :smiley:
