Author Topic: 1.8t won't start when up to temp  (Read 8439 times)
Offline Jonnybbad
Re: 1.8t won't start when up to temp
« Reply #30 on: 28 February 2012, 17:31 »
Exactly the same when I had my stage 2 and THS fmic fitted wasn't very impressed but put it down to them
Offline navmk4gti
« Reply #31 on: 28 February 2012, 17:37 »
Sounds like the customer service has gone down hill :lipsrsealed:
Offline JimBR
« Reply #32 on: 28 February 2012, 18:39 »
It wasn't the hype I was expecting that's all I'm going to say. However it was a cold Saturday morning  :grin:
Would have been nice to at least say hello to the guy who mapped it though.
Maybe its the volume of work nowadays meaning they haven't got the time.
« Last Edit: 28 February 2012, 18:41 by JimBR »
Offline palmtree
« Reply #33 on: 28 February 2012, 21:55 »
fitting new maf and crank sensor tomorrow so will see what it's like when there done
Clutch pedal switch have no idea about that but the revs drop as they should when the clutch is pressed
boost surge, could running with the maf unplugged be causing this?
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #34 on: 29 February 2012, 20:16 »
Had my car remapped on friday and there was no codes before getting it mapped, when they were taking the car off the rolling road it wouldn't start, so scanned it and told me it was just an immobilizer code and started once it was cleared. But i've been having problems starting the car when it's warmed up, starts fine when cold just not when up to temp scanned the car yesterday and got the following codes
17947 (P1539) clutch pedal switch
16706 (P0322) engine rpm sensor intermittent
01314 engine control module (could this be due to the car being remapped?)
Also the maf is unplugged because they said it was that bad it wasn't worth plugging back in
Any help appreciated
Hi! :smiley:
There where codes under laying and fuel trims of the scale before we worked on the car, which after a bit of time logging we found would not hinder the mapping we was going to carry out as the generic tables would work fine.  The crank sensor fault would on come back after a power run and the rpm went over 6500rpm.
 When the car was stock and we cleared the MULT fuel trims from -25% then car took a few turns on the key and around 8 seconds to start when trying to get the car on the dyno,  after the first stock power runs it was highlighted that the MAF reading where a mile out and eat way at the stock power, so the tuning session was carried out with MAF off and generic mod.  The reason the car would not start was beause the plugs would have got sooted up with the maf over reading and dumping the fuel during the last power run we ran the car with the MAF on to see how far the fuel way out and how it would effect the power, we read the codes from the ecu and only stored code was IMMO which I shouted to Jim , which was down to the ecu booting up for the map to be loaded which happend every time any ecu gets mapped.
Once you got the crank sensor fitted and fixed the other issues then the car should be spot on starting, there is nothing in the map which changes the start conditions or immo status only power when the turbo is on boost.
  The only thing a map can do is highlight under laying issues hardware issues, and clearing fault codes and restoring fuel trims ADD/MULT back to zero will also highlight fuel issues, starting issues, faulty maf ect..
If you have more under laying issues which have not come to light then these can lead on to warm/cold start issues,  ECT, AIT Thermostat ect..   Once you got all the bits fitted and fixed your welcome to pop down to have it all check out again and logged on the dyno to make sure there are no more silly underlaying issues and we could have more time to chat over some hobnobs..lol
When custom mapping on the dyno we dont use generic maps we are actually tuning the cars logging and getting our heads around the setup, some cars come in with unique setup ARZ ko3s with stock side mount, fuel ect.. we have to log and make our mind up what power is safe maxing the power out across the whole band would not me safe so we compromise, we found you car made good easy peak power and flow which we worked out and limited the peak torque to stop major heat build up at the top end,  if there where flow issues high up we would have worked on the midrange power.  but you car was unique and the setup you got was the safest.   We also limit torque if the car is seeing a lot of corrections on the timing, so if running cheaper 95fuel we can only tune with this fuel, if running v-power we can tune more.   The issues with the ARZ is that the me7.1knock control mapping is not as good as the later Me7.5 ecu in the AUM & AUQs so there is much smaller window for safe power.
When cars come in for generic remaps we have a 3hour window to talk chat have tea/coffee, banta, test drives in my car ect.. but if in for custom mapping then 3 hours located booked is used to test log and tune and maybe seem un-polite??  :embarassed:
You are booking our time to remap your car, in the past I have spent hours talking to customerd and cracking jokes ect which is good for PR, but means less time for mapping and logging the car, which imo is what counts and what we are getting paid for.   Rob is always on the phone which rings 24/7, Jims is on the dyno and I have to get my head around the car, logs, mapping, questions from rob and the feedback from Jim in the car.    If the mapping goes smooth and there are not major issues tuning or no faults which we have to pin point ect... Then we tend to bring customers in to the workshop when its safe and show them the actual mapping, live data logs, ect if we have time and we know the car is right.   :wink:
Its not our mapping going down hill or customer support, its just we are spending more time on the rolling road with each car and less time chatting while working.  In the past customers could come in to the workshop and stand close and chat, but due to H&S issues and liabilty policy issues we have to have customers outside workshop while a car is on the ramp and dyno.  If it was down to me I would have customer in the workshop all the time taking videos and picture and getting a buzzer from the sound and smells.  :grin:  But now we have a crappy portacabin with old TV an magazines as a waiting room, we are not like big tuners with fancy waiting room, playstation, sky tv, sales staff which have free time to chat but charge £500 for custom maps. Swings and around abouts.
I am sorry if you felt let down by the level of conversation and feedback during the mapping session, but me and Jim had good intentions of getting your ecu software and engine spot one and safe with what we had to work with in the session.
Nick
 01455 617233
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #35 on: 29 February 2012, 20:41 »
to be fair when I went up last time I said a quick hello when I arrived and a quick chat about the spec that had changed since the last time Nick tinkered with it then that was about it until a few hours later  :smiley:
Offline RTechUK
« Reply #36 on: 29 February 2012, 20:53 »
Thats what is like now most of the time sorry to say.  A lot of the issues is now cars coming in to us with issues which we investigagte in depth, wrong fuel and wrong hw mods, I am finding myself working extra hard on the mapping, logging, dyno and ramp getting them right and safe, even working for unpaid for 3hours and ending up not mapping a car  beacuse I am not 100% with how its running.
 The bliss jobs are the one which have 0% ADD 0% MULT fuel trims stock and zero CF stock... I can chill, relax and have some banta.. But the poor old 1.8T is getting old on the tooth now and need all my love.. :smug:
  Your car last time was on the verge of the fuel system and I needed to get my head around making at safe window so you didnt blow up on your trip home... plus needed to make good JKM dyno bragging numbers....lol
 01455 617233
Offline bobbieboy69er
  • MK4 1.8T AUM
« Reply #37 on: 29 February 2012, 20:56 »
Think thats a fair statement Nick.  like you say, try getting a Custom Remap elsewhere for the money you charge.  Swings and Roundabouts!
I understand what the Op is saying in a way.  Altho you cant give a running commentry of the work being carried out maybe a quick 30second update a couple of times during the session may help, its the not knowing whats goin on that kills ya!!
MK4 1.8T AUM|30mm Eibach Springs|Milltek cat back|4mo rear valance|pipercross filter|R-tech Stage 1 Remap|Baileys DV|Powerflex Front and Rear Bushes|312mm Front Brakes|Creation Motorsport TIP and hoses|17" TT Ronals|  220BHP
Offline topher
  • Administrator
  • fully functioning
« Reply #38 on: 29 February 2012, 21:13 »
it takes longer than 30 seconds just to explain what a fuel trim is in non-techy terms :grin:
Offline RTechUK
« Reply #39 on: 29 February 2012, 21:13 »
It would be nice to have it like the old days, taking customers out in my car and sh@tting the life out of them and having a social life at work ect.  But the market has changed, we have had to up the game not our prices, the market is full of tuners now who can remap 1.8t and give the best map out there but not being happy with the actual software mapping which causes map related issues. So now we do actaul custom maps for all stages when car are booked in at the workshop at the cost of more time spent on the dyno and crunching logs and data.
 The 1.8T engines are getting old now, and the generic maps aint cutting it or doing the older cars justice.
 01455 617233
