Author Topic: 1.8t won't start when up to temp  (Read 8440 times)
Offline palmtree
« on: 26 February 2012, 10:13 »
Had my car remapped on friday and there was no codes before getting it mapped, when they were taking the car off the rolling road it wouldn't start, so scanned it and told me it was just an immobilizer code and started once it was cleared. But i've been having problems starting the car when it's warmed up, starts fine when cold just not when up to temp scanned the car yesterday and got the following codes
17947 (P1539) clutch pedal switch
16706 (P0322) engine rpm sensor intermittent
01314 engine control module (could this be due to the car being remapped?)
Also the maf is unplugged because they said it was that bad it wasn't worth plugging back in
Any help appreciated
Offline Toby
  • Car - less
Re: 1.8t won't start when up to temp
« Reply #1 on: 26 February 2012, 10:19 »
Who the hell mapped that????
Currently down under
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 26 February 2012, 10:19 »
dammit Toby you beat me
Offline palmtree
« Reply #3 on: 26 February 2012, 10:20 »
R-tech
Offline Toby
  • Car - less
« Reply #4 on: 26 February 2012, 10:20 »
Really ?  :undecided:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 26 February 2012, 10:25 »
crank sensor is normally the culprit for not starting when warm
clutch switch - have you noticed the revs staying put when you change gears?
Offline houston
« Reply #6 on: 26 February 2012, 10:26 »
still surprised r-tech unplugged the maf and didnt tell you to replace it straight away tho.
and yeah crank sensor sounds the culprit
Offline palmtree
« Reply #7 on: 26 February 2012, 10:30 »
No they told me to replace it with a main dealer only one, they said it's not worth plugging in to get home with
Not noticed the revs staying while changing gear either as regards to the clutch pedal switch
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #8 on: 26 February 2012, 10:57 »
clear the codes and see what comes back  :wink:
Offline navmk4gti
« Reply #9 on: 26 February 2012, 11:06 »
do you live far from r-tech? .. you can trade in your old maf and pay £70 and get a new one from vw.. i did that about 2 years ago when mine went :wink:
