Author Topic: Oil pressure warning.  (Read 1943 times)
Offline stainesy
Re: Oil pressure warning.
« Reply #10 on: 26 February 2012, 09:51 »
 :rolleyes:  :grin:
As it only did it once when I first started the car and hasn't since and been driving it about all say. Going to assume it was just a little fcuk up and that's it. If it comes on again then I will do something about it.
Offline danny_p
« Reply #11 on: 26 February 2012, 15:35 »
youd be better off calling it a warning  that should be acted on.
if your oil pressure did actualy drop due to pickup issues it will do it again and it'll do it for longer, problem is next time it come in your likely to in the middel of nowhere with no phone signal or just down teh road from home and will push on thinking it'll be ok.   it will then go bang
all the VW's have gone bar 1.
Offline stainesy
« Reply #12 on: 26 February 2012, 17:21 »
Where is the oil pump in the engine?
Offline rockmonkey69
« Reply #13 on: 26 February 2012, 18:33 »
You'll see it once you open up the sump
« Last Edit: 26 February 2012, 18:35 by rockmonkey69 »
