Author Topic: car keeps stalling PLEASE HELP!!  (Read 2000 times)
Offline mrsaunders
« on: 24 February 2012, 21:19 »
Replaced the two green bungs by the tb, oil pressure sensor and breather pipe now a day later when I dip the clutch to change gear the idle drops low and 50% of the time its stalling
Offline gti gaz
Re: car keeps stalling PLEASE HELP!!
« Reply #1 on: 25 February 2012, 09:18 »
Is the tb clean comman to get stalling with dirty tb  :smiley:
 Any one in cornwall lets sort more meets!!!!
Offline mrsaunders
« Reply #2 on: 25 February 2012, 11:22 »
just done both and still doin it, it happens when i just tap the thorrtle mainly, then struggles to start
Offline VEEDUBMAD123
« Reply #3 on: 25 February 2012, 19:14 »
Hi mate is it a 2.0l 8v mine was doin it it needed a new throttle body i replaced and was perfect its the throttle stop switch goes funny
done one on my old mk3 2.0l 8v too........thanks Rik
Offline mrsaunders
« Reply #4 on: 25 February 2012, 19:23 »
did yours take 4 or 5 goes at starting sometimes? and its only on slight throttle if i rev it harder its fine, changed the arm dizzy and plugs no joy, how hard was it to change the tb?
« Reply #5 on: 25 February 2012, 19:28 »
no it would just cut out and start up straight away you might have a crank sensor fault you need to get it scanned for fault codes,
i'm a motor vehicle technician of 26 years so if you want help i'll give you a hand if you want so can you get it scanned for codes...rik
Offline mrsaunders
« Reply #6 on: 25 February 2012, 19:39 »
i'll look for some software and a cable, its odb 1 do you no where i could find what the codes mean, im in kent aswell so you might be a long way away
« Reply #7 on: 25 February 2012, 19:51 »
ok mate when i mean i help you i mean on here fella get the codes and i'll find out for you,you can get a plug in scanner on ebay for £70ish i got mine on there it does loads of things it reads codes cancels codes and much more worth the money i'll get the name of it for you.....Rik
What year is your car the OBD socket is next to the ashtray remove the ashtray the panel to the left of the ashtray slides to the right and its there....
Offline mrsaunders
« Reply #8 on: 25 February 2012, 20:01 »
yeah i found the port by accident a few months back, and its m reg at the very start of 95
Offline mrsaunders
« Reply #9 on: 26 February 2012, 14:08 »
stalling has stopped (for now) its just taking a few goes at starting up and sounding abit rough, also replaced ecu relay and fuel pump relay
