Author Topic: Interior/exterior led's  (Read 911 times)
Offline bigmarky
« on: 20 February 2012, 14:25 »
Sure there will be a million posts on this but what do I need sizes,numbers of bulbs to replace the interior and exterior bulbs to led, and will I need error free ones for my 1999 AGU ??? Before I order them cheers.
Tornado Red, 99 AGU, full milltek, K & N, forge007p, 18\" A8 in custom Matt Black with Anthracite inserts, Custom remap, 22psi boost, HID\'s, full led\'s, bodykit.
Offline richw911
Offline bigmarky
Re: Interior/exterior led's
« Reply #2 on: 20 February 2012, 19:37 »
Cheers saw that just wondered the sizes, ie 39mm and again about the canbus type for my car????
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 20 February 2012, 19:47 »
Can bus doesn't exist on the mk4
Offline Chris#101
« Reply #4 on: 20 February 2012, 19:50 »
Glad this popped up
am I right in thinking the following
Door puddle lights = c5w x 1 per door!?
Interior light = c5w x1 !?
Map reading lights = 501/w5w x1 each side!?
CHEERS   :wink:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline symsymma
  • AGU POWER,drive it like u stole it!!!
« Reply #5 on: 20 February 2012, 20:41 »
I got told today AGU ok but later ones might have a problem :undecided: fitted led sidelight bulbs in me new lights today and all ok.mines AGU :smiley:
1.8T AGU 203bhp & 233lb/ft Rtech stage 1 custom remap,18"dezentz rims,lowered 40mm shocks n springs,whiteline 24mm adj rear arb,lcr axle bushes,polybushed arb,modified front bumper & valences,depo projector headlights,delocked,wrapped interior&bora gear knob,forge boost & coolant hoses,forge tip,forge 007p,samco vac hoses,simota aeroform cai,saiko michi catch can,deleted pcv system,r32 dogbone,miltek lg bore down pipe & sports cat/non res anni style system.
