Author Topic: What bolt on mods are required for stage 2 r-tech  (Read 3735 times)
Offline ryan360
« on: 18 February 2012, 19:51 »
Hi just a quick question, i currently have a AGU 1.8t 20v a3, (k03) with a 3" decat turbo back exhaust, Cold air induction cone filter, vr6 clutch, and a new dump valve coming soon.
At first i was just going to go with a stage 1 remap, but would it be worth getting a stage 2 with the mods i currently have?
And also, is a fmic required for stage 2 or can u run the standard smic.
Thanks Ryan :)
« Last Edit: 18 February 2012, 20:02 by ryan360 »
Offline symsymma
  • AGU POWER,drive it like u stole it!!!
Re: What bolt on mods are required for stage 2 r-tech
« Reply #1 on: 19 February 2012, 21:04 »
Hi mate for stage 2 you could do with a silicone tip pipe,and boost hoses.would deffo get a k03s.as for i/c side mount would b ok but fmic would be better imo :smiley:
« Last Edit: 19 February 2012, 21:13 by symsymma »
1.8T AGU 203bhp & 233lb/ft Rtech stage 1 custom remap,18"dezentz rims,lowered 40mm shocks n springs,whiteline 24mm adj rear arb,lcr axle bushes,polybushed arb,modified front bumper & valences,depo projector headlights,delocked,wrapped interior&bora gear knob,forge boost & coolant hoses,forge tip,forge 007p,samco vac hoses,simota aeroform cai,saiko michi catch can,deleted pcv system,r32 dogbone,miltek lg bore down pipe & sports cat/non res anni style system.
Offline Wazzzer
  • Golf GTI 1.8T AGU
« Reply #2 on: 19 February 2012, 21:29 »
Have a look through my spec list to give yourself an idea, link in my sig below
Standard SMIC can be run but you risk not getting the most out of the map. I would say an uprated SMIC at the least is needed
Offline lukeyyyyyyy21
« Reply #3 on: 20 February 2012, 18:05 »
 I am a fan of getting a SMIC as they require no aditional pipework and hassle etc... BUT surely as they are much deep in dept, a great big cube intercooler will create lag as its all being condensed, where as Audi TT have two intercoolers one at each end including a crosspipe so its gradually condensed down...Which is why I think a FMIC would give best results????
Anyone compared or had experience with SMIC VS FMIC?
Offline Wazzzer
  • Golf GTI 1.8T AGU
« Reply #4 on: 20 February 2012, 18:09 »
My Golf with the SMIC made 225bhp  :smiley:
Offline Chris#101
« Reply #5 on: 20 February 2012, 19:33 »
Might aswell add a forge actuator to the list if your going stage 2  :cool:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
