Author Topic: Temp issues  (Read 1665 times)
Offline dannydubs
  • mk2 gti,mk3 wagon,mk5gti
Temp issues
« on: 15 February 2012, 11:23 »
Got a 1.8 driver having a little issue with temp car runs fine,fans working fine
Car is Geting up to temp and sitting over half way
Sitting at around 100-110 but doesn't go higher or over heat
I've read some where if it sits below middle it's one thing or sits over middle it's another
Thing just can't remember which or what
I'm guessing either temp sensor or themostat?
Any one help?
.....the project.........
Offline Seanl
Re: Temp issues
« Reply #1 on: 15 February 2012, 12:14 »
Could be either, but more likely to be temp sensor. Change that out first, but if no luck go for the stat. Usually the stats stick open, but if yours is not fully closed and stuck there, it will only be allowing a small amount of coolant to circulate, thus running at a higher temp. Thermostat is cheaper, but will take far longer, and be far more a pain in the arse to change. Temp sensor will take 2 minutes to do.  :smiley:
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: Temp issues
« Reply #2 on: 15 February 2012, 16:53 »
Yea sounds like the stat is stuck half way, its cooling the engine sufficently to prevent overheat but not enough to keep it at 90c.  But a new temp sensor will never hurt on a MK3. lol
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline dannydubs
Re: Temp issues
« Reply #3 on: 15 February 2012, 17:11 »
Dnt think it's the sensor and thermostat is opening
As bottom hose is Geting hot
Offline Rmachines
Re: Temp issues
« Reply #4 on: 15 February 2012, 17:15 »
The bottom will get hot, as the stat will be opening, which will balance the rad with the rest of the system but its not letting enough through to fully cool it,    To be totally honnest, theres not much else it can be, its a simple system on these, so either its too hot due to the stat or its fine and the sensor is telling porkies.   I have never seen a sensor over read to the gauges though, my money is on the stat.
Offline dannydubs
Re: Temp issues
« Reply #5 on: 15 February 2012, 18:29 »
Just had another look gets to just under 110 then fan kicks in drops back down to
100 ish then back up 110 again then fan again just keeps doing this cycle but
Doesn't over heat no warning lights
All mk3,s I've had just sat in middle and never moved
Offline Rmachines
Re: Temp issues
« Reply #6 on: 15 February 2012, 20:07 »
Actually, thinking about it, its going to be the temp sensor, as the fan switch will kick at just above 90, if it was the stat causing it to run higher, then fan would always be on untill it reaches half way,  so if the fan kicks when it over half way, and goes off before its exactly half way, it can only be the temp sensor givin the wrong signal,   Unlikely to be the stat, and a lazy fan switch.
Offline javalin
Re: Temp issues
« Reply #7 on: 16 February 2012, 13:17 »
I thought the radiator fan switch kicked in at > 100c?  Thus I'd have said the CTS was OK and its a stuck T-stat or a blocked rad, etc.
Have you tried bleeding it?  Not likely but might be worth a go.
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline Rmachines
Re: Temp issues
« Reply #8 on: 16 February 2012, 14:13 »
Im not to sure when the fan kicks in but i do know the gauge doesnt move from half way before it kicks in, so theres not much in it.
Offline javalin
Re: Temp issues
« Reply #9 on: 16 February 2012, 14:20 »
well it will be over 90c for sure, I am fairly sure its 105c or so, i.e. it shouldn't kick in during normal operation.
