Author Topic: 280mm or 288mm?  (Read 3055 times)
Offline CJA321
Re: 280mm or 288mm?
« Reply #10 on: 14 February 2012, 10:17 »
How can you tell there reps btw?
Well i havnt had any issues with them so far and they torque up okay  :smiley:
Re: 280mm or 288mm?
« Reply #11 on: 14 February 2012, 10:44 »
They are 5x100 so will be reps, check the wheels and see but I suspect they are square taper, standard bolts are radius fit.
Offline CJA321
Re: 280mm or 288mm?
« Reply #12 on: 14 February 2012, 13:45 »
Well the wheel nuts are tapered, and so is the wheel if thats what you mean?
Offline tweed
Re: 280mm or 288mm?
« Reply #13 on: 14 February 2012, 17:55 »
standard up top, after market bottom. Iv n
Untitled by tweedub, on Flickrever used standard bolts on after market wheels.
Offline CJA321
Re: 280mm or 288mm?
« Reply #14 on: 14 February 2012, 19:02 »
Hmmmmmmmmmmmm it that much of an issue? I actually bought the car with the wheels so know very little about what went on haha!! Theres no spoggot rings or anything thou, and fit okay i thought   :grin:
Re: 280mm or 288mm?
« Reply #15 on: 14 February 2012, 20:02 »
As per tweeds pic, you should be running the bottom bolts but check the wheels and see if the bolt holes are the same taper, stange you have no spiggot rings they might be direct fit however.
Offline CJA321
Re: 280mm or 288mm?
« Reply #16 on: 14 February 2012, 21:36 »
Yeah they are direct fit  :smiley:
Re: 280mm or 288mm?
« Reply #17 on: 14 February 2012, 23:48 »
When you get chance, take a bolt out and check the seat.
