Author Topic: From Jap to Vag *27/11/13 car being returned to standard lots of parts for sale  (Read 132956 times)
Offline andynorfolk
  • if at first you don't succeed, get a bigger hammer
Re: From Jap to Vag *No More S#it 25/03/12*
« Reply #50 on: 26 March 2012, 22:07 »
pretty sure they're pretty similar to the mk2 coilovers in which case they're a piece of p1ss and won't take you long at all, they're cheap too for budget ones :D
let me know if you need a hand at all :P
Offline Chris#101
« Reply #51 on: 27 March 2012, 12:15 »
I might just take you up on that offer  :wink:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline Chris#101
« Reply #52 on: 28 March 2012, 22:06 »
Can anyone clarify if I've plumbed in my catch can right? :)
Also is it normal to show up on my boost gauge on idle at -30 since fitting the catch can  as begore it used to sit at -20!?
Cheers guys
Offline Chris#101
« Reply #53 on: 01 April 2012, 20:20 »
Update 01/04/12
APRIL FOOOOLS  :grin:  :grin:
Took a trip to my local dealers on satdee to see what I could waste my money on haha
Also got myself a W8 light to match the bora vents :cool:
and fitted, so much nicer and clears the screen alot better than before
Whipage
3.6 liter, 40 vavle, twin turbo, 330bhp
the out come, didnt have time to get it stuck down
? :smug: ??
Even though Ive just brought a brand new genuine OEM K series K03s turbo to try and solve my oil burning issue she has been booked in for good messure to get the following replaced;
 :nerd:
Head gasket
cylinder head skim
valve stem oil seals
timing belt
water pump
I believe there is a metal propelled water pump you can get!? can anyone point me in the right direction??
all comment welcome
cheers for reading
« Last Edit: 01 April 2012, 21:08 by Chris#101 »
Re: From Jap to Vag *Car stolen 01/04/12*
« Reply #54 on: 01 April 2012, 21:07 »
You can get them however the view seems to be stick with the plastic version it is modified now and much safer than the metal version if it seizes
Offline Chris#101
« Reply #55 on: 02 April 2012, 12:26 »
Cheers wayne, I take it that its the OEM VW that has been modified to be stronger!?
any idea on price?
has there been a few isssues with metal ones seizing?
thanks  :smiley:
Offline topher
  • Administrator
  • fully functioning
Re: From Jap to Vag *Car stolen :(*
« Reply #56 on: 02 April 2012, 12:54 »
i've heard the stories but never actually seen one seize up, i have however now seen 2 of the metal impeller type start leaking due to premature bearing wear.
Offline Chris#101
« Reply #57 on: 02 April 2012, 19:58 »
Orite that is interesting Chris, plastic one it is then  :nerd:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #58 on: 05 April 2012, 21:08 »
my previous metal water pump leaked due to this
Offline bricey
  • One of a few with a PROPER engine
« Reply #59 on: 05 April 2012, 21:13 »
chris i may know you i lived around there for a long time
but moved to iow as im a grandad and love the quiet life lmao
« Last Edit: 05 April 2012, 21:15 by bricey »
DOLPHIN TRAINER
